dfkrug
Super Member
- Joined
- Feb 3, 2004
- Messages
- 7,783
- Location
- Santa Cruz Mtns, CA
- Tractor
- 05 Kioti CK30HST w/ Prairie Dog backhoe, XN08 mini-X
I guess to "stow" the thumb the cylinders are left in parallel and spread until the thumb is in the stowed
position and then the switch is thrown into "curl only"?
Ya beat me to posting the link. You may have found the other discussions about this, too.
When in grapple mode (both cyls connected in parallel) and the dipper is extended out past
perpendicular, operating the bkt dump lever will pressurize both cyls, but only the thumb
will move cuz gravity works for it, and against the bkt. I turn the switch off as soon as the
thumb is 180-deg to the dipper, and there it stays.
I did numerous experiments, mockups, and calcs to come up with a design that works
very well for over 5y of moving hundreds of rocks and trees. WITHOUT using additional
work-port RVs. In that time, I have replaced one damaged hose, and added a few welds
to cracks in my 12" bkt. One day I might weld some hose protection to the dipper.
At the risk of repeating what I put in the above thread, part of making this work is
building a thumb that withstands the reaction forces of the bkt. Obviously the cyls
should be the same size, but I also used 4500psi wp hoses, and fabbed a welded cyl that
can take 3500psi. Oh, and 1" pins.
