Backhoe Stand
/ Backhoe Stand #21
The Kubota B26 backhoe manual says to block under when disconnecting but not how much. It was a real pain to connect to if on the ground. Simply used some timber screws and four pieces of 4x4”, 4x6” short lumber scraps to make box frame pallet. 8” off the ground. Being screwed together the Blocks don’t slide or roll when disconnecting or connecting and supports are in the right place. Now R&R is easy, quick and safe.
The larger M59 backhoe has no problem being stored on the ground.
Can you post a picture of it? I have a B21 which is similar and found the process to be a bit dicey as I don't have a concrete slab for the purpose.
/ Backhoe Stand #23
The backhoe has settled back some in the months of storage even through the lines are connected together and all valves were operated when disconnected. Important safety considerations to always be aware of with equipment such as this.
(2) 15.0/55-17 TIRES W/ 6 LUG RIMS (A64280)
(2) 15.0/55-17...
2019 ISUZU NPR 4X2 S/A 18FT FLATBED (A59912)
2019 ISUZU NPR 4X2...
Caterpillar 910 Wheel Loader Parts and Service Manuals (A63117)
Caterpillar 910...
Chevy 2500 HD 4WD (A63689)
Chevy 2500 HD 4WD...
2000 Ford Windstar Van (A61574)
2000 Ford Windstar...
UNUSED WOLVERINE HYD MINI 4IN1 BUCKET (A64281)
UNUSED WOLVERINE...
