Backhoe Backhoe removal
/ Backhoe removal #1
ABE56
I know its here somewhere here but are there easier instructions that whats printed in the manual for removing a Woods BX90 from my L3400. Want to try a few implements but am nervous about the removal (and re-attachment)of the Backhoe. Thanks for your help
/ Backhoe removal #2
It used to be that way for me too until I became more adept at using the stabilizers and the bucket to relieve pressure on the attachment points so pins could move more freely. Now I can drop it in a couple of minutes and re-mount it in only a few more. The more you do it the better you get at it.
/ Backhoe removal #3
That's very true indeed. Especially the last part "The more you do it the better you get at it".
Familiarity and knowing what to look for makes it a lot easier. You find yourself looking at those spots that always give you trouble. Then you'll figure out how to position the hoe to overcome the binding. I use the hoe bucket and the stabilizer legs to get it just right so it comes off easy. Then I try to keep it in that same position for remounting. Pretty soon it becomes no big deal.
/ Backhoe removal #4
I was having problems with my hoe "relaxing" after a month or so. I place concrete blocks under it to maintain a heighth so I put the PTO shaft for the pump on and then raise/lower stabilizers and bucket/boom for attachment on the tractor. My hoe doesn't come off often so it takes some time to get it off/on, usually around 15 minutes off/ 20 minutes on (depends on how straight I can line it up).
Good Luck! The first times ALWAYS the hardest!
/ Backhoe removal #5
The first time I removed mine, I went play by play from the manual. It came off nice. Take your time, read over the instructions, and then follow them. I am as new to this as can get. I built a small stand for my backhoe, which I am going to try out tonight.
/ Backhoe removal
Thanks guys, I have 15 acres that I just had cleared. So now I want to max the L3400 and get a york rake and a harrow to smooth out the fields. The terrian In New Hampshire is fairly rocky (the granite state) So now comes the fun part of trying to smooth out my fields
/ Backhoe removal #7
Dont want to take over your thread, but my stand worked out perfect. I will post some pics, but I was busy back blading 8" of snow. Only 2 more feet to go today.
/ Backhoe removal #8
For re-attachment it is very important that you brace the hoe so it stays in pretty much the same position as when you took it off. I have learned that by propping in up with boards and making sure it does not "settle" makes re-attachment much much easier.
/ Backhoe removal #9
Hey guys here are those pics as promised. It came off so easy. It should go on the same, but been too busy with snow removal w/ back blade. It moves around better than I thought, even with the small casters, and brken concrete floor.
/ Backhoe removal #10
Great idea for the wood stand. Still working good for you?
