Backhoe Backhoe question
/ Backhoe question #1
RandyS
CT and upstate NY
Jinma 204, Mahindra 2816, Prowler mini skidsteer
A neighbor is giving me a backhoe attachment. If I'm not mistaken it said Kubota 4520A on it. Has a big frame that goes with it.
It's been sitting outside for quite a while and needs new hoses and to be cleaned up. Anything else I should look for?
Also gave me a 3PH Kubota finish mower, also been sitting outside and needs cleaning.
Some days are just better than others!
Thank you.
/ Backhoe question #2
<font color="blue"> Backhoe question </font> /forums/images/graemlins/confused.gif
Your question is?
Will it fit your tractor?
<font color="blue"> A neighbor is giving me a backhoe attachment. </font>
I'm sure for that kind of money you can make it fit.
/ Backhoe question
Just want to know what to look for in fixing it up. Will not fit my tractor, already know that. Do I need to go to a Kubota dealer for the lines or can I just get some made up, things like that. There is some rust on one cylinder, whay can I do about that? Sorry for not being more specific.
/ Backhoe question #4
I would look for a local shop that makes hydraulic lines. Try NAPA.
Some TBNer's have used this place. Hose & Fittings.com
Try using Scotch Brite to polish up rod. You may have to replace cylinder seals if rust is not removed before cyclinder is moved.
/ Backhoe question #5
Randy what tractor are you trying to adapt it too? Do you know what model the subframe is for?
Andy
/ Backhoe question
AndyMA,
Not trying to make it fit my tractor. Have a backhoe on mine already. I was just going to get it and clean it up and Ebay it. Could use the money for a down payment on a new zero turn mower. Not sure what Kubota model it came off of. It's in the guys barn and I didn't go in and look at it. Probably about 25 horsepower.
2018 Deere 770G (A64126)
2018 Deere 770G...
2016 Ford Explorer (A59231)
2016 Ford Explorer...
2019 Mack Granite Tri-Axle Dump w/ Lift Gate 006043 (A62613)
2019 Mack Granite...
Skid Steer Blank Plate (A65640)
Skid Steer Blank...
2016 John Deere 6155R (A64126)
2016 John Deere...
Kubota Diesel Utility Tractor (A62679)
Kubota Diesel...
