Backhoe Backhoe question and advice
/ Backhoe question and advice #1
Lynn_O
Ok, planning on buying a DX33 or equivalant. What size and
brand BH do you think i show get. And what and average
price for such a BH, with a subframe mount. Also another
dum question. If i go with a subframe mount backhoe can i
detach the backhoe to run a finishing mower, and if so how
hard is it to do.
/ Backhoe question and advice #2
Don't know about the DX33 or what brand of BH to suggest for this tractor, but I would suggest a subframe mount for the backhoe.
Most all subframe mounts are rather simple to attach and you should have no trouble switching from the backhoe to any other implement. /forums/images/graemlins/grin.gif and WELCOME TO THE BEST TRACTOR FORUM ON THE INTERNET. /forums/images/graemlins/grin.gif
/ Backhoe question and advice #3
could someone post a picture of the backhoe subframe without the hoe on. I also am concerned about using 3pt with the subframe, but have not seen one.
/ Backhoe question and advice #4
Not sure about the DX but on my New Holland the front subframe brackets bolt right where the belly mower brackets go. You can still use a 3ph mower easily enough.
I went with the Bush Hog backhoe. Subframe mounted with rear remote was $6100 or $6500 installed. I put it on myself and saved $400. It was easy to install. I went with the Bush Hog 750. It's a nice sized hoe and would work well with your tractor or you may want to move up to the 850.
buckeyefarmer:
I don't have any pictures of just the subframe. On mine when removing the hoe, the subframe stays with the hoe leaving just 4 small brackets attached to the tractor. There's nothing left to interfere with the 3ph.
PICS
Thanks for the welcome aboard
Hey, thanks that really helps out. Pictures really look good.
Could not tell from the pictures, what size tractor and HP.
Also i am going to probably get turf tires, since i had my 5 acres leveled and dont want to make any more ruts. Do you
think i need to have my rear tires filled or something, if i get
a BH, and if so, what is there on the market to fill with.
/ Backhoe question and advice #7
Welcome to TBN from a native buckeye! One of the great features of TBN is the search engine... you can find something on almost any tractor topic.
In May, 2004, one of the regulars here, txdon, posted a series of pictures of how the Kubota BH90 backhoe goes off/on his L5030. That should give you a very clear sense of what is involved. My computer skill isn't up to actually adding the link to those pics in this message, but if you use the search feature in the Kubota Owning/Operating section, and search for BH90, it will turn up.
The changeover from BH to 3pt. is easy. The toplink just pops off, and you have a couple of pins to pull for each of the lower links. 2 minutes, even for a slow poke like me. Another couple minutes to get the BH and tractor lined up, and you're done. It's really only a 10-15 minute job, once you've done it a few times.
/ Backhoe question and advice #8
When you want to add a link to another page or site, copy the URL/Address by highlighting the address bar and right click, choose copy. Then when you post, type your message, click on URL in Instant Markup below where you type your message. Right click in that pop up window and choose paste to put the address in there and click ok then type in a name for your link in that pop up, click ok and your link is now in your post.
When searching, make sure you choose a time frame from the drop down windows. The default selection is only newer than 1 week, so you may need to increase the time up to newer than one year or choose All Posts.
John
/ Backhoe question and advice #10
Lynn,
The tractor is the TC30, rated at 30hp. I have loaded R-4's on mine. You may want to check to see if turfs are ok to use with a backhoe. I don't know but I think turfs usually have less plies and may not be rated for the load. Some one else here may know for sure.
It's not necessary but it helps to have loaded tires. My dealer fills them with anti-freeze. Some people use windshield washer fluid. Also used is calcium chloride and a newer product called beet juice. The pros and cons of each are discussed in several threads on this board.
Good luck with the tractor purchase!
Rodger
/ Backhoe question and advice #11
Here is a link to Lynn's other post in the Case/IH Forum. That post sheds a little more light on the issues. Lynn is not only trying to find the best tractor, but also trying to find the best combination for finish mowing and a backhoe. I suggested he post in these general forums so he would get a lot wider range of experience. Since I don't have experience with a backhoe or a finish mower, I knew I could only talk in generalities. I hope Lynn can find more details to help with his decision in this forum.
Lynn's Case/IH post
/ Backhoe question and advice #12
Lynn, I have the NH TC30 and own both the BushHog backhoe with subframe mount and a mmm mower. As others have stated switching from bh to 3ph is no problem. Switching to mmm is going to be a bigger job. Just had the mower mounted so haven't tried it myself yet. First to go from bh to mmm, all 4 of the bh subframe mounting brackets will have to come off, then the mounting brackets etc for the mmm go on. Maybe someone who has taken a mmm mower (and brackets) off and on could tell both of us how big a job that is.
/ Backhoe question and advice #13
Thanks for the feedback and pictures.
Now all I need is money....
/ Backhoe question and advice #14
You should look at the Woods backhoes, they offer a couple of models for this tractor all are subframe types.
/ Backhoe question and advice #15
If I can generalize.....a MID-MOUNT finish mower will almost always interfere with at least the front tractor-side bracket of a subframe hoe. A THREE-POINT finish mower often will not interfere with the rear tractor-side bracket of a subframe. With that in mind, I have installed a Woods factory subframe on a Kubota once (not the newer 4-pt Woods mounts) where the rear tractor-side bracket kept you from using the 3-pint at all. Not very convenient.
/ Backhoe question and advice #16
</font><font color="blue" class="small">( I have installed a Woods factory subframe on a Kubota once (not the newer 4-pt Woods mounts) where the rear tractor-side bracket kept you from using the 3-pint at all. Not very convenient. )</font>
The new 4-pt Woods mounts don't have that problem.
John Mc
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2014 Ford Transit Connect Handicap Van (A61573)
2014 Ford Transit...
2019 John Deere 314G Compact Wheel Loader Skid Steer (A64553)
2019 John Deere...
(INOP) 36 BLADE DISC HARROW (A64278)
(INOP) 36 BLADE...
JOHN DEERE 7410 TRACTOR (A64278)
JOHN DEERE 7410...
2019 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A64553)
2019 ASV RT-25...
