Backhoe backhoe purchase
/ backhoe purchase #1
radman
Kubota L3710, JD5300, AC D19, IH 806, IH 8950, Ford 8N, Farmal Super M, several others in the past.
Just purchased a used Bradco backhoe model 611 for my Kubota 3710. It was used on a skid loader and I will need to purchase a subframe. Bradco doesn't recommend the 611 for my kubota due to the power of the hydraulics but I intend to use it occasionally and gently. No rocks in my area. Bradco does make a subframe to match the hoe. Bradco recommends 9-12gpm hydraulic output and the 3710 puts out 8 gpm. Does anyone know it the hydraulics will be sufficient or should I consider a pto pump?
/ backhoe purchase #2
MChalkley has a Bradco 609 on his L4310 even though the Bradco specs call for more flow than his implement pump puts out. If you search on "Bradco" and then read the posts written by MChalkley, you will find some where he goes into great engineering detail as to how he hooked up the hoe to the tractor hydraulics. He commented that the slightly insufficient flow slowed down the hoe in some circumstances but that he found the combination suitable for his requirements (which are very exacting).
54in Wagon Wheel (A65583)
54in Wagon Wheel...
ASV Engine & Parts (A66285)
ASV Engine & Parts...
New/Unused Quick Attach Pallet Forks (A65583)
New/Unused Quick...
2021 International HX620 Quint Dump (A62613)
2021 International...
82" X 18' EQUIPMENT TRAILER (A64277)
82" X 18'...
GREAT PLAINS TURBO-MAX 1200 - 12' VERTICAL TILLAGE (A64277)
GREAT PLAINS...
