Backhoe Backhoe purchase
   / Backhoe purchase #1
kolob5
Southern Indiana
Branson 3820 Yanmar 2002
I've got a chance to pivk up a John Deere 48 backhoe for a good price. Could it be adapted to mount on my Branson 3820? Thanks in advance.
   / Backhoe purchase #2
If you know what you are doing you should be able to modify it to fit.
I have a Branson 3510 and I bought a new leftover Jinma Hoe on ebay for $2200. I had to modify the subframe to fit my tractor and add rear hydraulics. I do have a fabrication/Welding shop so it wasn't very hard for me.
I did have problems with the Chinese hose fittings and had to make some adapters but I powered through it.
   / Backhoe purchase #3
I am 99% sure that the deere backhoe is made by Ameriequip which is the same maker of the Branson backhoe. You can more than likely pick up the right sub frame from a Branson dealer and it should bolt right up!:thumbsup:
   / Backhoe purchase #4
As far as I know that Deere 48 is in fact an Amerequip 8600, which is what I have on a C42 (Large Frame).
It should fit right on if you can get a sub frame - getting a sub frame could be a problem.
EDIT;
Sorry Wallace, didn't see your post before I posted.
Chances are we're either both right or both wrong, but at least we AGREE (-:
;END EDIT
PS If anyone comes across a 12 inch or so bucket for one of these - for CHEEP ! Please contact me (-:
   / Backhoe purchase
Thanks for the info, the hoe was gone when I got there. Maybe I'll run across another good deal.
1994 Mack CH613 T/A Wet Kit Day Cab Truck Tractor (A50323)
1994 Mack CH613...
2017 Ford Fusion Sedan (A50324)
2017 Ford Fusion...
2015 Caterpillar 259D (A50120)
2015 Caterpillar...
2019 Case-IH 370 Steiger (A50120)
2019 Case-IH 370...
2015 FORD F-250 SUPER DUTY (A52472)
2015 FORD F-250...
