Backhoe Project Photo
/ Backhoe Project Photo #12
Glenn1-- last summer i built the cad plan 608 with the extended boom, power beyond valve, joy sticks, 15" and 6" buckets for my 15 hp kubota three point hitch and was the best thing i ever built. I started a thread on this site then if you want to see it. If you need any suggestions, let me know, am more than willing to help.
arkydog
I am currently building the 608. Any helpful hints on assembly? Where did you install the grease fittings?
I have the main structure complete, except for two pieces that were missing from the kit, the main boom and the pivot assembly. I am currently working on the short section of the boom. I called John and he is sending out the missing parts.
Sorry for the delay in responding, I have been riding by Harley across Kentucky, Tennessee and Georgia for six days.
I am building the model 608 with extended boom and joy sticks. I have needed to call twice concerning questions and found them very helpful.
/ Backhoe Project Photo #15
Glenn1-- The grease fitting i installed after I had all the bushings made, inserted and fitted with the pins cut and the tabs welded on the ends. Then with every thing taken apart, I drilled the zert fitting into the bushing end making sure that on full movement that they wouldnt hit anything. Reassamble each part with pins installed and bolted, drill or mark pin thru zert hole, and remove pin and cut groove around pin with edge of grinding wheel about 1/64" deep. As seen in the pictures, also cut your spacers before you grove pins. Drilling the zert fittings was one of the last things i did.
arkydog
/ Backhoe Project Photo #16
If you have a picture of the extended boom, could you post one or two of it? I would like to see how it is designed.
I have a photo but having trouble getting the size down below 100KB to place on the site. I will post ASAP.
Boom with photo.
Arkydog
I am very interested in your suggestions and comments. What is the title of your thread? I do have some concerns on weld size, it is hard to estimate force on each joint. Do you have any photographs? How is the operation?
HUSQVARNA RIDING...
JLG E300AJ (A60462)
JLG E300AJ (A60462)
CHALLENGER MT525B TRACTOR (A59823)
CHALLENGER MT525B...
2015 Ford F-150 Pickup Truck, (A60352)
2015 Ford F-150...
FLARE STAND (A60736)
Giyi Gy-BS72B QA BoxBroom Sweeper (A60463)
Giyi Gy-BS72B QA...
