Backhoe piston broke
   / Backhoe piston broke #1
seniornukect
2021 Massey Ferguson 1835M
Anyone run into this issue with a woods bh75? I am digging a trench for water and power lines and found a good sized rock. No way to lift it out so I dug a deeper hole behind it and when I went to push it back with the bucket I heard a bang and the dipper arm swung loose. Found the half of the eyelet in the hole, no sign of the grease fitting. It looks like really cheap pot metal.
   / Backhoe piston broke #2
Maybe a bad casting? Was this the first time you've used the backhoe? It looks like it can't have many hours on it. It's WAY too clean!!
First major job with it. Took down bushes and brush before.
   / Backhoe piston broke #4
Do you still have warranty? Otherwise a hydraulic or machine shop should be able to get it fixed.
   / Backhoe piston broke #5
At least it's an easy fix! It just didn't survive your first shake-down cruise with the new backhoe. First time you really stressed it.
I'll be surprised if Woods or your dealer doesn't just give you a new cylinder to pin on.
   / Backhoe piston broke #6
I'm a bit surprised on how thin the ring looks that broke. Would have expected something a bit more robust from Woods
   / Backhoe piston broke #7
Woods probably just buys the cheapest cylinders they can find.
Made in China!
   / Backhoe piston broke #8
Made in China!
In general I've observed woods to be better than a northern tool/harbor freight production. Perhaps that's changed.
   / Backhoe piston broke #9
I agree that the first step is to try and get woods to do a warranty replacement.
   / Backhoe piston broke #10
Replacement cylinder AND pin, for at least that side.
Kinze 600 Grain Cart (A52349)
Kinze 600 Grain...
John Deere 893 Corn Head (A50514)
John Deere 893...
2014 Ford Explorer AWD SUV (A50324)
2014 Ford Explorer...
Kubota L2501D 25HP Utility Loader Tractor (A50322)
Kubota L2501D 25HP...
2015 TRANSMASTER LOWBOY TRAILER (A52141)
2015 TRANSMASTER...
Woods 3 pt RM 550 Finishing Mower (A50515)
Woods 3 pt RM 550...
