Backhoe piston broke
   / Backhoe piston broke #1
seniornukect
2021 Massey Ferguson 1835M
Anyone run into this issue with a woods bh75? I am digging a trench for water and power lines and found a good sized rock. No way to lift it out so I dug a deeper hole behind it and when I went to push it back with the bucket I heard a bang and the dipper arm swung loose. Found the half of the eyelet in the hole, no sign of the grease fitting. It looks like really cheap pot metal.
   / Backhoe piston broke #2
Maybe a bad casting? Was this the first time you've used the backhoe? It looks like it can't have many hours on it. It's WAY too clean!!
First major job with it. Took down bushes and brush before.
   / Backhoe piston broke #4
Do you still have warranty? Otherwise a hydraulic or machine shop should be able to get it fixed.
   / Backhoe piston broke #5
At least it's an easy fix! It just didn't survive your first shake-down cruise with the new backhoe. First time you really stressed it.
I'll be surprised if Woods or your dealer doesn't just give you a new cylinder to pin on.
   / Backhoe piston broke #6
I'm a bit surprised on how thin the ring looks that broke. Would have expected something a bit more robust from Woods
   / Backhoe piston broke #7
Woods probably just buys the cheapest cylinders they can find.
Made in China!
   / Backhoe piston broke #8
Made in China!
In general I've observed woods to be better than a northern tool/harbor freight production. Perhaps that's changed.
   / Backhoe piston broke #9
I agree that the first step is to try and get woods to do a warranty replacement.
   / Backhoe piston broke #10
Replacement cylinder AND pin, for at least that side.
2019 Isuzu NPR-HD 24ft. Box Truck (A50323)
2019 Isuzu NPR-HD...
Highway Products 8' Truck Bed Tool Box (A50515)
Highway Products...
2014 Ram 1500 4x4 Crew Cab Pickup Truck (A50323)
2014 Ram 1500 4x4...
2008 Ford Escape XLT SUV (A51694)
2008 Ford Escape...
2003 Lincoln Aviator (A50515)
2003 Lincoln...
2008 John Deere 2305 Tractor (A50514)
2008 John Deere...
