BACKHOE PART ??
/ BACKHOE PART ?? #1
DIRTCUTTER
New Mexico
CK30 HST
kb2375 Backhoe What is the part that is attached to the dipper that tells you when the bucket is level to the ground. Its a rod that slides in a tube. I looked in my parts manual no luck.I need to replace it, bent all to heck.
/ BACKHOE PART ?? #2
Never seen a level indicator on the backhoe...They are on the front loaders.
/ BACKHOE PART ??
You are right sir. Have been working in the hot sun and wasnt thinking when I posted.
Do you know whats it called
/ BACKHOE PART ?? #4
Bucket level indicator.
/ BACKHOE PART ?? #5
If the rod is all that is bent or even the tube, you might be able to weld the bracket on to a steel rod and/or tube from the hardware or steel supply store and make a new one. Maybe even make it out of stainless. Just a thought if you or a friend has a welder.
/ BACKHOE PART ?? #6
Do you really need it as front top edge of the bucket really tell you the angle your hitting the dirt with, i never really use the bucket level rod thingy.:)
(INOP) 2018 BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) 2018 BOMAG...
UNUSED WOLVERINE RSB66-66" ROCK SCREENING BUCKET (A64281)
UNUSED WOLVERINE...
2022 RBR Venturi 430 High-Capacity Pneumatic Applicator (A63688)
2022 RBR Venturi...
2011 TRAIL KING TK70MG-523- 52' LOWBOY TRAILER (A64280)
2011 TRAIL KING...
Kubota V3600-E3-EG60 Diesel Engine - 3.6L - Tier 4i - Irrigation Pump Takeout (A63689)
Kubota...
2005 International 4300 Rollback (A62613)
2005 International...
