Backhoe no up or down
/ Backhoe no up or down #1
Richard Tractor
Jinma
Greetings, Tractor bin sitting couple years at daughters, hot here summers, Running no everything works except raising or lowering ! 😒What think you ???
It's a Jinma, backhoe working when I moved it down here,
Guess I'll open it up and tap the valves lightly
Been years since I was on this site, re registered, forgot my username, may have been Valley Ranch,
Thanks guys for coming on to help🙏
Haven't changed the hoses , Tomorrow,
Never put off for tomorrow what you can do day after tomorrow,
Mark Twain
By the way guys when I pull back on the lever to raise the upper part of arm the pump is struggling to move fluid an the ram extend about 1/2"
/ Backhoe no up or down #9
Is the fluid clean or has dirt/water/etc gotten into the system? And it has the proper amount of fluid?
First guess is fluid is not flowing to the cylinder that raises and lowers. If all the hoses are properly connected, maybe a stuck control valve from sitting?
Tapped valves lightly with hammer, upper end moved couple inches two or three times then nothing,,,
I fluid is clean and filled, just tapped the valves lightly with hammer, upper end moved slightly, couple inches two or three times now nothing again,
/ Backhoe no up or down #15
Are you able to raise and lower the front end loader? Can you also raise and lower the outriggers on the backhoe?
Front end loader works, that is separate hydraulic system,,,
Outriggers raise and lower properly,,,
/ Backhoe no up or down #20
So the only problem is the largest cylinder at the bottom of the boom that is supposed to raise and lower the boom isn't working? The outriggers and the bucket cylinders appear to be working normally?
If this is what is going on, it just seems like you aren't getting any fluid flowing to the boom cylinder and my first suspect would be the control valve not letting fluid flow.
Was the machine left out in the weather all this time?
Hurricane THB750 Hydraulic Breaker Excavator Attachment (A61572)
Hurricane THB750...
Decorative Turtle Statue (A61574)
Decorative Turtle...
UNUSED WOLVERINE HYD BRUSH CUTTER (A64281)
UNUSED WOLVERINE...
2021 John Deere HD35R Draper Head (A63111)
2021 John Deere...
(2) 25X10.00-12 TIRES W/ 4 LUG RIMS (A64280)
(2) 25X10.00-12...
iDrive TDS-2010H...
