Backhoe joysticks
/ Backhoe joysticks #1
Shovelhead76
Coos bay/Valdosta
Mahindra 2015
Hello,I have a mahindra 2710 backhoe with about 2000 hours and the joy sticks are worn out .Dealer wants $530 each.Is there a replacement or am I stuck.Thanks
/ Backhoe joysticks #2
No idea on your machine, but generally you can buy aftermarket from hydraulic shops or ebay, they may be as low as half price, but then they don't fit in the same location, they may have fittings in different positions, so brackets, fittings, time,.......... I'd probably try to push the dealer for a better price, try him for $400 a piece and see what he says, because you don't want to go knocking him on the forums! Also since it's only a few years old, perhaps mahindra corporate may come good with something when you complain about longevity, 700 hours per year is only 2 hours per day. Otherwise start looking on line to see what else you can find/adapt........
/ Backhoe joysticks #3
Is it the joysticks or the hydraulics? The joysticks pivot in a ball and pull on linkages that control the hydraulics. Have you checked the linkages and connecting pins? What are the symptoms that leads to a worn out joystick diagnosis?
/ Backhoe joysticks #4
Yeah, my first thought was these "heim joints". You can buy and replace these individually, from generic
sources. Hoe owners often fail to keep them lubed with an oil can of real oil (not WD40).
If the valves are shot, then it is gonna cost. Is it a Bradco hoe? Mahindra uses them as a supplier. Before
I paid over $500 per valve section, I would try to repair them, or buy a whole new stack for about $1K.
/ Backhoe joysticks
Thank you all for the info.I had to run back to Oregon but now in Georgia.I picked up some levers and controls for outriggers.They work great and only 120.00 each.Again Thank you all for the Help
/ Backhoe joysticks #6
Supply Center (they advertise on here too) probably has them aftermarket.
I have not done this yet, but my single lever bulldozer control lever is $1000 just to fix all the roll pins and linkages, that is NOT the hydraulic control either...just the pins and linkages! Fooey with that, I can buy a controller new from Supply Center for $279. It has 3 handles instead of one like the factory, but jeesh...
/ Backhoe joysticks #8
Find a local hydraulic shop. They can usually rebuild any hydraulic component. Ask the loggers in your area which shop they use.
hugs, Brandi
/ Backhoe joysticks #9
I just purchased the joystick setup mentioned above by jay4200 for my backhoe project. The trick is trying to figure out which direction in stick movement triggers which port. The directions are pretty awful.
2000 Chevrolet Malibu (A62613)
2000 Chevrolet...
6x12 Leonard Utility Trailer (A65579)
6x12 Leonard...
Kuhn FC 4000 (A64126)
2007 Chevrolet Silverado 1500 Truck (A63116)
2007 Chevrolet...
2016 Ford Escape SUV (A61569)
2016 Ford Escape...
17in. Bucket w/ Teeth Excavator Attachment (A64194)
17in. Bucket w/...
