Backhoe hydraulic hose won't go on
   / Backhoe hydraulic hose won't go on #1
chuckles148
NB, Canada
Kioti CK2610
Does anyone else have an issues connecting the hydraulic hoses to the rear of the tractor. The only way I can get mine on is to hit the end with a hammer until it releases enough pressure I can connect it.
Any thoughts would be appreciated.
   / Backhoe hydraulic hose won't go on #2
Before you disconnect it, shut the tractor off and wiggle the stick until all the pressure is off. The hoses should feel sloppy- loose before you disconnect them. Then disconnect the hoses and they should go back on easy when the time comes.
   / Backhoe hydraulic hose won't go on #3
If you disconnected it WITHOUT getting all the pressure off, or did and still are having problems reconnecting, it may be due to thermal expansion of the hydraulic fluid.
You need to "relieve the pressure" in the lines. This can be done in various ways such as pressing the fitting against wood so it leaks a little, loosening the fitting so it leaks, or cooling it down.
For example I disconnected my backhoe on a cool spring day then tried to reconnect on a 99 degree summer day after the black hoses had been basking in the sun. The fluid had expanded. I grabbed a garden hose and hosed down the hydraulic hoses with cool water.
   / Backhoe hydraulic hose won't go on #4
Before I hook the hoses up for my bh, I run all the control levers through their travel and make sure no cylinders are moving. This seems to balance any pressures and the QDs connect. When disconnecting the hoses, I do the same prior to disconnecting with the tractor not running and the remote still in the on position.
   / Backhoe hydraulic hose won't go on #5
I do the same as others before I disconnect I shut the tractor down and wiggle all the joysticks to get all pressure out of the system
   / Backhoe hydraulic hose won't go on #6
Sometimes around here when it's hot the oil will expand and I have to push the ball in until it relieves the pressure.
JOHN DEERE ROW MARKERS - SET OF STACK FOLD 12 ROW 30 INCH ROW MARKERS (A55315)
JOHN DEERE ROW...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
INDUSTRIAS AMERICA F12T HYD TILT LAND LEVELER (A51406)
INDUSTRIAS AMERICA...
2019 Allmand Night-Lite V-Series 7kW S/A Towable Light Tower (A55973)
2019 Allmand...
2018 KAUFMAN 44 FT CAR CARRIER TRAILER (A57880)
2018 KAUFMAN 44 FT...
2015 Chevrolet Tahoe SUV (A55853)
2015 Chevrolet...
