Backhoe Backhoe Filter
/ Backhoe Filter #1
pej2945
Tennessee
Jinma 284 & Jinma 354LE
Has anyone added a filter to their LW-6 Backhoe? I would like to add an in-line filer but I’m not sure what line to install it on. Also with metric fittings and hoses I’m not sure where to get the parts. Any information or pictures would be greatly appreciated
/ Backhoe Filter #2
i´d added a suction-filter in the oiltank on my lw-6. all you need is a 1/2" connector, teflon, and the filter. all thogether for ~ $ 12-15. prefer filters with bypass wich open when filter is closed this prevent damage the pump. there are also magnetic-filters availible wich are a better choise.
do not forget to change / inspect the filter in future!
please see attached picture.
/ Backhoe Filter #3
if you put a inline filter on the suction side make sure it is no smaller than 150 micron or you can starve the hydraulic pump and burn it up.
/ Backhoe Filter #4
Also, you can install a vacuum gauge between the filter and the pump suction, and change the filter ~20".
/ Backhoe Filter #5
Yes, I have. Although I'm using a Prince pump, the routing would be the same. I also added a 0-60 psig gauge upstream of the filter, and a thermometer downstream. Since it is installed on the return line, I used schedule 40 3/4" black pipe & fittings, and #12 Aeroquip reuseable fittings. No additional hose was needed, in fact I had to remove 12" from the return line.
/ Backhoe Filter #6
Bob which model of the Prince pump are you using? GPM? Thanks
/ Backhoe Filter #7
It's the HC-7A, 7gpm.
/ Backhoe Filter #8
Many thanks Bob, does it work well? The reason I ask is that someone told me that the Hydraulic pump supplied by Jinma is 11 GPM. If it works well for you that is what I will get.
Thanks again for quick response.
/ Backhoe Filter #9
Bob:
I have never seen the LW-6, 7, or 8s up close and I have a question:
it seems that the main joystick controls keep you from operating the
2 valves on each joystick simultaneously. From your photo this seems
due to the X-shaped cutout in the control panel cover. It that your
experience? I have never operated a hoe with this apparent limitation.
Also, since you installed a thermometer, what is a typical and max
temp you see after operating the hoe for a while?
/ Backhoe Filter #10
I must have talked to the same guy you did and I bought the 11gpm model. Well that turned out to be a BIG mistake; too violent when running at r/m's; too much juice! Considered a flow control valve, but that would cause too much heat, so I bought the HC-7A 7gpm unit. I belive the OEM pump is around 6+gpm. It works great. BTW, I have an 11gpm unit for sale-only has 15 minutes of time on it.
dfkrug said:
it seems that the main joystick controls keep you from operating the 2 valves on each joystick simultaneously. From your photo this seems due to the X-shaped cutout in the control panel cover. It that your
First; I don't think you can make compound valve movements with the same valve handle, but I do using two separate handles/functions. BIGGKIDD has a LW-7 on the CTOA site and he shows where he cut out the X's with a hole saw (nice job too), but I didn't hear any feedback on how it works.
Second; Depending greatly on ambient conditions, it will get up to 192°F after working it very hard for ½ an hour. Still well within the limits of the Rykon AW32 oil.
/ Backhoe Filter #11
Yes, you would have to cut out the 'X' to be able to use the joysticks
properly. That is my point and that is why no other hoes do it that
way. If you can not feather one of the sticks to operate both valves
simultaneously, then you are missing out on an important capability.
/ Backhoe Filter #12
I understand exactly what you mean, but being an open centered system with no hold, it's not likely to work. If you take a good comparative look at the Chinese valve operators, you wouldn't want to compromise an already precarious arrangement of dubious quality. I understand that these machines are not Caterpillar quality, and treat them accordingly.
/ Backhoe Filter #13
I does work, but it takes practice. Valve quality is important. Working
with only one pump does have its limitations, but feathering one of the
valves causes a certain amount of back-pressure that allows the circuit
doing more work to get some flow. I was able to do this with my old
home-built CADDigger that had Prince stack valves and no joy sticks. It
is easier with my current Prairie Dog that has some unbranded Bulgarian
valves WITH joysticks. I find that larger balls on the tips of the joysticks
help, too.
/ Backhoe Filter #14
The BH does not have the same valve operator gates as the 6-way dozer blade, on which I can do compound movements simultaneously. Oh well, no big deal. I'm used to it, and it pays by the hour anyway.
2021 YANMAR VIO25-6A EXCAVATOR (A63276)
2021 YANMAR...
TERRA TRACK TRACKED WORK  VEHICLE
TERRA TRACK...
227 (A64278)
227 (A64278)
2022 Power Screen Phoenix 3300 Tri-Axle Trommel Screener (A64194)
2022 Power Screen...
2002 Mitsubishi Lancer Sedan (A64557)
2002 Mitsubishi...
2022 EZ-GO ELITE...
