Backhoe bucket recommendations
/ Backhoe bucket recommendations #1
Notforhire
Southwestern Virginia
Kubota L47TLB
I'm getting a BT1000B backhoe for my L47TL and I'm trying to decide on a do all bucket for it.
I expect that I'll be mostly digging out small stumps, planting trees/bushes, some trenching for culverts, water and electric lines cleaning out ditch banks , that sort of thing. I don't plan on doing any major excavation for basements or anything like that. I had a full size TLB in the past, but have no experience with a compact TLB. I would like a decent size bucket without overtaxing the machine. The soil around here is mostly rocky sandy, after you get through the red clay topsoil.
I was thinking of a 18 inch or maybe a 24 inch max. I won't have a thumb. I would appreciate any advice from you folks that own, or have rented similar sized equipment.
/ Backhoe bucket recommendations #2
There’s no do it all bucket. I have a 16”, 24” and 36” on my M59. I got the 36 for putting in fill lines. It’s really too big for the machine and I wouldn’t recommend anything bigger than 24” especially for a smaller backhoe. A 16” is a lot better general purpose bucket. A 12” or a ripper would be better for stumps. I’m not a fan of 12” or smaller buckets because they pack full and won’t dump.
There’s no do it all bucket. I’m not a fan of 12” or smaller buckets because they pack full and won’t dump.
Maybe I should have called it a "make do" bucket, but I know what you mean. Having a selection is always better. I agree with you on the 12 inch buckets for the same reason.
I'm leaning towards a 18 as a compromise.
/ Backhoe bucket recommendations #4
That’s probably the best compromise but not very good for stumps: I really want a ripper for mine.
/ Backhoe bucket recommendations #6
I have a 24" bucket on my L48 TLB, but would really like to have/find a good used 16" one.
Used Kubota QA buckets seem to be hard to find.
/ Backhoe bucket recommendations #7
1st thing get a thumb you will never regret it especially since your digging stump and roots.
I have b26 and have 12,18 and 30" all have there place but 18 gets the most use with 30" close second, it's a smooth bucket and I used it cleaning up ditches and when backfilling.
/ Backhoe bucket recommendations #8
Wider is always better takes out more material faster and if you're doing a trench it's wide enough for you to get in the trench if needed.
24" never come off my backhoe even though I have a selection of buckets.
/ Backhoe bucket recommendations #9
My 12 packs with clay mud, but I'm not sure my little dipper could safely handle anything much wider. Maybe a 16-18 at the most. Also has welded on teeth, so no smooth scraping.
I'd love to find an affordable round edged bucket to scrape ditches, or an add-on round edge attachment to fit over the teeth.
/ Backhoe bucket recommendations #10
Agreed. If you plan on digging a lot of stumps get the thumb and narrower bucket like 16-18inch. I use a 24 inch bucket and think I would like a ripper to cut through the roots easier and leave smaller holes to fill.
You wont regret adding a thumb, only not getting one sooner.
/ Backhoe bucket recommendations #11
I have a quick change setup and often shift between a stump ripper, a 6" trenching bucket, a 12" digging bucket, and a 24" smooth landscaping bucket. And a hydraulic thumb. Having a choice of tools adds a huge amount of utility to the small backhoe.
Having a thicker wallet would greatly add to my ability to buy more buckets.:laughing::laughing:
Unfortunately all I can afford right now is one. With the amount of backhoe work I have to do, I find it hard to justify the backhoe itself.
/ Backhoe bucket recommendations #13
I don't have your answer, but here are some things that I hope are as fun to think about as they were to write....
We've had an M59 since 2007. It has the slightly larger BT1200 backhoe, a hydraulic thumb, and two QC buckets - a 12" and a 24".
Yep, it's not an L47, but hopefully things are proportional. The L47 and M59 do have the same engine. The difference being the turbo.
NotForHire....You are going to hate this....but I wish there was some way you could try ours with a thumb. That one addition makes the backhoe into an entirely different machine and gets as much or more use for lifting, craning, and placing heavy items than for digging. Especially for landscaping. Everyone who has a thumb on theirs is going to say the same. I don't know of a single other tractor feature with that much agreement.
As for buckets, the tractor simply doesn't notice any difference power-wise between the 24" and the 12". What turned out to be more important is the type of soil. Ours here is a sandy, gravely mountain dirt without any clay and with darn little loam. It's pine tree country..... For digging in that type of soil I always go with the 24" to get more width on a trench because the sides are going to slump and collapse and we will end up moving a lot of dirt. Plus I have more control over the shape of the edge of the trench with the larger bucket.
The 12" doesn't load up badly on our soil, but I can sure see where it would in clay. Mostly what I use the 12" bucket for is for grasping things with the thumb - because the thumb is also 12" wide. That makes it real handy handy for picking up & building rock walls, setting fieldstone pavers, or carrying logs.
For digging and especially for ripping on roots, stumps, hardpan, or buried rocks, I go back to the 24". The 24" has more than plenty of power on the M59 - frankly neither bucket taxes the machine at all. That's not a problem. It can rotate either bucket with enough force to pick up the machine at full stretch, and can use the 24" at full side extension with a loaded bucket without feeling like anything is being stressed. I would assume the L47 is proportional. The TLB backhoe is beefy with a big swing platform and large swing bearings.
I see where Kubota offers an 18" for the BT1000. That smaller bucket wouldn't look quite so out of place as the wide 24". But I'd rather it was 20".
Hear on TBN I've heard some say to use a smaller bucket for ripping & stumps but can't see why one would. The 24" rips just as well and moves more dirt doing it. I just don't see any digging advantage to that smaller bucket. Of course that might just be me and our "soil". i.e. application-dependent.
Through the years I have several times tried the 12" when I got into some roots that the 24" couldn't rip or cut, but the 12" didn't have any advantage. Neither bucket did any damage to the worst of the stump roots. Stumps usually mean having to dig a huge deep hole....and the 24" does that better.
Here's something else to think about that I didn't know before the Kubota. We had off-brand & aftermarket hoes before, and they came with several no-name buckets. the Kubota has taught me the value of a good bucket shape. Both these Kubota buckets have large heavy teeth (5 and 3 respectively) as well as a good progressive curved shape to the bucket bottom. The bucket sides are the right height and more importantly the sides are heavily built with a welded-on cutting edge. I didn't realize just how much bucket bottom shape, side reinforcement, and teeth counted for before this one. I'd say that the Kubota bucket shape is every bit as good as the JD310, and might even be a tad better.
rScotty
rScotty
I hope you folks don't misunderstand me. I have no doubt that any kind of thumb would be a great addition, as well as a selection of buckets. I thought about renting a machine like mine and see how it acts with the supplied bucket. Unfortunately the rental yard is at least 25 mi away. My "test" would cost me at least 50% of a new bucket.
I've budgeted the backhoe and a bucket for 2020. Any additional thumbs/buckets will have to wait until 2021. :laughing:
Interesting you mention Kubota offering a 18 inch for the BT1000. On the L47 build your own page, for a 18 inch pin on bucket, it says L45. All the other buckets 12,16, 24, 30, 36. make no mention of the L45. I don't get it?? Is there something different about the 18 in and if so why is it included in the list of buckets for the L47?:confused3:
https://apps.kubotausa.com/configurator/BuildMyKubota.aspx?pgId=4&bmId=1099&sId=124
/ Backhoe bucket recommendations #15
I don't even attempt to justify my backhoe!
I have a 2006 Kubota L48 TLB, that I absolutely do not need,..... but I want it,..... and I will keep it,..... until I croak!
I probably only use it 15 hours each year.
I am now in my 80th year, and I absolutely don't care if anyone else thinks I need it or not.
I want it!
I like having it!
I will keep it!
I am too old to need a reason why!
/ Backhoe bucket recommendations #16
rScotty
The hydraulic thumb was one of the bigger reasons I bought my M59 to begin with. It was on my must have feature list when I bought it. And the Kubota thumb meshes with the bucket right. It’s much better than a after market flat thumb for trying to pick up small things. IMG_7867.JPG
Thank you all for your thoughts and opinions.
I placed my order today for a BT1000B and a 24 inch bucket. I think that I'll get a 16 inch later on.
I'm beginning to think you guys own stock in the thumb manufacturing company.:rolleyes:
That too will have to wait until I bring it to congress in 2021 and see if she will release the funds.
"I have a 2006 Kubota L48 TLB, that I absolutely do not need,..... but I want it,..... and I will keep it,..... until I croak!
I want it!
I like having it!
I will keep it!
I am too old to need a reason why!"
I like the way you think!
Any thoughts on non hydraulic thumbs?
/ Backhoe bucket recommendations #18
I'm beginning to think you guys own stock in the thump manufacturing company.:rolleyes:
I want it!
I like having it!
I will keep it!
They’re about as good as a prosthetic hand. And not a good one at that. A hydraulic is Way better. And I have zero financial interest on hydraulic thumbs.
/ Backhoe bucket recommendations #19
I want it!
I like having it!
I will keep it!
I will say you back will thank you as will your executive committee, as you will use the thumb more than regular backhoe work. Say its 2k I don't know but over next ten years amounts to lots of fun use that you will fight with out it. My executive director had me use my to clean up her flower beds the other day and to replace landscape timbers.
/ Backhoe bucket recommendations #20
My "executive committee" resigned 22 years ago.
My purchases are now ...... "approval not required".
I have had an interim committee for the past 19+ years, but it has never been officially recognized, so approval is not required.
2014 FORD F-550 XL SUPER DUTY UTILITY/SERVICE TRK (A59823)
2014 FORD F-550 XL...
2019 KUBOTA SVL75-2 SKID STEER (A62129)
2019 KUBOTA...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A61307)
2023 Unverferth...
Sdlanch 12'x20' High End Carport (A60463)
Sdlanch 12'x20'...
2018 Ram 1500 Crew cab (A59230)
2018 Ram 1500 Crew...
Mini Ex Rake Attachment (A60463)
Mini Ex Rake...
