Backhoe bucket recommendations
/ Backhoe bucket recommendations #1
Notforhire
Southwestern Virginia
Kubota L47TLB
I'm getting a BT1000B backhoe for my L47TL and I'm trying to decide on a do all bucket for it.
I expect that I'll be mostly digging out small stumps, planting trees/bushes, some trenching for culverts, water and electric lines cleaning out ditch banks , that sort of thing. I don't plan on doing any major excavation for basements or anything like that. I had a full size TLB in the past, but have no experience with a compact TLB. I would like a decent size bucket without overtaxing the machine. The soil around here is mostly rocky sandy, after you get through the red clay topsoil.
I was thinking of a 18 inch or maybe a 24 inch max. I won't have a thumb. I would appreciate any advice from you folks that own, or have rented similar sized equipment.
/ Backhoe bucket recommendations #2
There’s no do it all bucket. I have a 16”, 24” and 36” on my M59. I got the 36 for putting in fill lines. It’s really too big for the machine and I wouldn’t recommend anything bigger than 24” especially for a smaller backhoe. A 16” is a lot better general purpose bucket. A 12” or a ripper would be better for stumps. I’m not a fan of 12” or smaller buckets because they pack full and won’t dump.
There’s no do it all bucket. I’m not a fan of 12” or smaller buckets because they pack full and won’t dump.
Maybe I should have called it a "make do" bucket, but I know what you mean. Having a selection is always better. I agree with you on the 12 inch buckets for the same reason.
I'm leaning towards a 18 as a compromise.
/ Backhoe bucket recommendations #4
That’s probably the best compromise but not very good for stumps: I really want a ripper for mine.
/ Backhoe bucket recommendations #6
I have a 24" bucket on my L48 TLB, but would really like to have/find a good used 16" one.
Used Kubota QA buckets seem to be hard to find.
/ Backhoe bucket recommendations #7
1st thing get a thumb you will never regret it especially since your digging stump and roots.
I have b26 and have 12,18 and 30" all have there place but 18 gets the most use with 30" close second, it's a smooth bucket and I used it cleaning up ditches and when backfilling.
/ Backhoe bucket recommendations #8
Wider is always better takes out more material faster and if you're doing a trench it's wide enough for you to get in the trench if needed.
24" never come off my backhoe even though I have a selection of buckets.
/ Backhoe bucket recommendations #9
My 12 packs with clay mud, but I'm not sure my little dipper could safely handle anything much wider. Maybe a 16-18 at the most. Also has welded on teeth, so no smooth scraping.
I'd love to find an affordable round edged bucket to scrape ditches, or an add-on round edge attachment to fit over the teeth.
/ Backhoe bucket recommendations #10
Agreed. If you plan on digging a lot of stumps get the thumb and narrower bucket like 16-18inch. I use a 24 inch bucket and think I would like a ripper to cut through the roots easier and leave smaller holes to fill.
You wont regret adding a thumb, only not getting one sooner.
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
2015 Volkswagen Golf Hatchback (A60352)
2015 Volkswagen...
Brock 48'x16' Flat Bottom Grain Storage Tank (A57148)
Brock 48'x16' Flat...
2016 Chevrolet Caprice Sedan (A61569)
2016 Chevrolet...
2008 CAT 305C (A53317)
2020 BOBCAT E42 MINI EXCAVATOR (A60736)
2020 BOBCAT E42...
