Backhoe blade
/ Backhoe blade #1
Volp
Stockholm and Raskarum, SWEDEN and Porreres Mallor
Massey Fergussom MF35, Kubota B6001, JD LX186 Lawn tractor. Ford Super Dexta 3000
I have been working with the instalation of my new pool and used my backhoe level the ground. I find it difficult to get a good finish with the bucket ( about 30" wide).
Have any of you build a blade to fit a backhoe instead of the bucket?
If the construction is not too complicated I might build it myself. I have made a rippel tooth of simple design which works quite well.
/ Backhoe blade #2
Anders, I would just use your back blade to smooth up the area after you finish digging with the backhoe.
/ Backhoe blade #3
We built a couple of them for a local landscaping company. The hoe bucket goes into the back socket, then pins on.
/ Backhoe blade #4
I've seen a backfill blade that bolts onto the bucket. Basically you just remove the two outer teeth on the bucket, and the blade bolts on.
I can't find the link/picture - it may have been discussed on TBN somewhere.
/ Backhoe blade
Thanks Jim!
Your picture looks like the conception I was thinking about.
Thanks also to rlw and EdKing.
Maybe it is easier to bolt something to the bucket than making a new outfit to replace it.
/ Backhoe blade #6
One of the guys showed me a neat trick for that. He has a JD 455 with all toothed buckets. He welded up two pieces of flat stock into a V shape that slips on over the teeth. One end is welded closed the other has a small locking pin, on and off in a snap.He then has a smooth, flat surface to scrape and grade with.
/ Backhoe blade #7
An old excavator I knew had a simple setup on his case 580. A 1/2" flat plate bottom(a bit bigger than the bucket), a plate welded on either side with a couple of holes drilled/bolted thru the bucket, slipped on similar to a tooth bar on the FEL. Made for quick removal/installation without removing the bucket. It worked on all sorts of slopes/angles. Now this guy on his old Case had the touch of a surgeon and could smooth out an area that I couldn't match with a rake by hand.
Pose this question to WroughtnHarv and with his welding abilities, the guy will have one fabricated, installed, tested and photo's posted before you're even finished typing up the question.
/ Backhoe blade #8
Here is the link.
<A target="_blank" HREF=http://www.hallsdirtblade.com>http://www.hallsdirtblade.com</A>
/ Backhoe blade #9
I have a 38" one that we made from a garden tractor back blade. It has a 16" peice of 3"x5", 1/4" wall square tube, vertical support. That is slotted to fit over the center tooth and 5" up the bottom of the bucket. And is held on with a the T handle and screw, cut from an old (large) C clamp.
Mounted on the Woods 7500 BH, it works quite well. strong yet light weight.
/ Backhoe blade #11
Very interesting! I haven't seen one of these but can see it's value. It also got me to thinking. Does anyone make a landscape rake attachment for a backhoe? It wouldn't be hard to build I'm sure. I've been thinking about what I can use to clean and rake the woods around my house which is on a slope that is to steep and to narrow between the trees to drive a tractor. A land scape rake, say 36" on a backhoe seems ideal.
Any thoughts?
mike
/ Backhoe blade
Well Rocky2, it seems that your excavator friends device is similar to the other ideas presented on this thread. As a surgeon myself I am sorry to say that my touch with the scalpel is not transferable to my handling of a backhoe!
/ Backhoe blade #13
Well that does it I guess I can't procrastinate any longer, I'm just going to have to go out and get one of those new fangled digi-thingy cameras. I'll post pictures of it and some of my other interesting projects as soon as I do.
That was an neat idea about mounting a lanscape rake to a backhoe. My mind is already whirring with ideas. I could use an old cut down landscape rake attached as I described in my post about the BKH blade. Or just get some 3"x3" angle and buy some new LSR teeth and bolt to it, still using the same method of attaching it.
/ Backhoe blade #15
I welded 3/4" by 8" grader blade 40" long to some old teeth already installed on 36" bucket. Then u can take off when not using and put teeth back on.I have this on a Deere 710 tlb and dig basements and finish grade with it.
/ Backhoe blade #16
JimMc,
Do you have a source for a moldboard "blank"? My summer project is to build a backblade for snow removal and grading. Presently, I have a length of 15" wide channel, which must be bent to form the moldboard....a project I am not looking forward to. I don't mind (in fact, enjoy) building from scratch, but a pre-formed moldboard would really help. Thanks,
OkieG
/ Backhoe blade #17
We fabricate our moldboards in several steps. They are first cut with either a CNC high definition plasma or laser, depending on the model. The blank plate is then rolled in a plate roll, and finally the stiffening bend and offset for the cutting edge are processed in a CNC break.
Although this is a more expensive process than most manufacturers use, it results in a high quality moldboard with the radius exactly matching the curve of the cutting edge allowing a smooth transition from edge to moldboard.
I suppose we could make a moldboard available as a replacement part, but obviously if you buy the individual parts to make a blade it would probably end up costing more. Of course, if you just enjoy the challenge of "rolling your own", it's probably worth it. (I know I do)
2021 CATERPILLAR 299D3 SKID STEER (A60429)
2021 CATERPILLAR...
UNUSED IRANCH HYD THUMB CLAMP (A60432)
UNUSED IRANCH HYD...
2025 DIGMASTER DM100 EXCAVATOR (A60430)
2025 DIGMASTER...
*Selling at Royal Auction Tampa, FL Location* (A59228)
*Selling at Royal...
2023 BOBCAT E88 R2-SERIES EXCAVATOR (A60429)
2023 BOBCAT E88...
2011 JLG E400AJP BOOM LIFT (A60429)
2011 JLG E400AJP...
