Backhoe attachment
/ Backhoe attachment #21
Top link bracket will only fail in tension, but you can crank the top link to be in compression. Its not gonna punch through the back of the tractor!
As far as hydraulics, they will either come from the loader valve power beyond and then back into your tank/sump, or the 3pt will have some external port to let you power it from the 3pt area. Gotta post pics of your loader valve or 3pt/underseat area, or i gotta spend a lot of time on google.. lol
Here's the loader valve
Another picture
/ Backhoe attachment #24
I would suggest you start with Messicks parts list for your B1550 and or get a service manual. Kubota B1550D (4wd) Parts
You need to locate the power beyond connection then the return line. In a sense you are adding a set of rear remote valves needed to run the BH. The BH will have two lines - a pressure and return line to the sump that need to be connected.
You could also search for BH install on the 1550 as well..
With seat removed
I believe these little tractors used a pto mounted pump ?
/ Backhoe attachment #27
Some Kubotas. Not all, offer a heavy duty top link bracket. To better distribute the weight. I looked into when my father got his 9000 backhoe but the bracket wasn't available for his model.
That would be a good idea. They do put a lot of stress on the top link bracket and if there was some way to spread that stress out to more mounting points that would be good.
John, how do you plan to get the hydraulic to the BH? I always ended up with a PTO pump and dedicated sump on mine.
The guy I bought it from says he has the 2 lines from backhoe hooked up to his front loader control ? Not sure I can do it on mine. Trying to get some insight on how from here. Trying to avoid the cost of a pto pump if I can
/ Backhoe attachment #29
Some did and some didn't. It was less expensive to buy a BH which used tractor internal hydraulics, and of course it made the whole rig lighter. Using a PTO driven pump made a whole lot more flow available at lower tractor RPM, and the remote reservoir held more fluid which made it cool better...plus having a filter on the remote reservoir kept the tractor hydraulics separate from any contamination. But it added considerably to the price of the hoe. Mechanically for the hoe iteself they were identical either way.
rScotty
Just found this in the manual. Is this where the BH lines would go ?
/ Backhoe attachment #31
That's great! I'm impressed. It says all the right things & I'm not seeing any problems. It even uses the existing relief valve. The only question remaining is what type of thread is that port, and where you want to put the quick disconnects.... are they to becloser to the BH or to this remote outlet port. .
It also says maximum weight for Backhoe should be 600lbs....ugh
/ Backhoe attachment #33
Maybe you had better look into it a little more. Find out why 600 lbs is the limit. It might be that Kubota rated that 825 lb 3pt spec you mentioned at the ends of the 3pt arms instead of a foot or two back from that point.
Certainly backhoes can put a lot of downforce on the tractor when they are digging. To the tractor, the vertical component of the digging force is no different than weight.
\It is common even with a big BH to get the bucket hooked under a root or something that won't give. Then instead of the bucket scooping soil, the tractor bounces around. That's why hoes can be hard on tractors. They don't have to be, but operators find it hard to resis throwing the tractor around with the hoe.
Are you having second thoughts about overstressing your tractor?
/ Backhoe attachment #34
Nice job posting helpful pics, nothing much left to guesswork now.
On your loader valve you have a port marked PB. That will now lead to the inlet of your backhoe valve. Whatever hole that PB hose is currently hooked to, is what your backhoe return line will plumb into. (y)
I seriously doubt you will have trouble with the backhoe weight.
Consider this: A B6100 tractor is much smaller than yours, ~1000lbs bare weight. Its 3pt can only lift 500lbs. Yet, they put a B670 backhoe on it which weighs 750lbs, and it's fine. I should know, ive been fixing up my buddy's 6100&670 for too long, a year this month, and ive put some hours on it and its JUST FINE.
Now could you get away with the backhoe without already having the front loader? No, not really. But you do! So, carry on.
As far as putting stress on the tractor, sure some is more than none, but the factory backhoe subframes ive been around are hooked up in such a way that they protect the tractor very well from anything other than you picking it up and dropping it hard repeatedly (user error). The top link is really only needed (if at all) because the backhoe/subframe assembly is, aside from the digging arm, a giant L with the long end sticking under the tractor and the short end sticking up behind the tractor. The top link is mostly there to keep you from changing that 90 degree angle in the L, to some other angle. But you can set the top link in a way where for it to put tension on the top link bracket, it would have to bend the subframe mounts first. But i wouldn't even worry about it!
I've been operating excavators most of my life so no worries about stressing the tractor being my fault and it has a pretty heavy sub frame. More concerns with transport weight and doing wheelies. I may have to put some ballast in front bucket
Don't I lose my loader function by doing that ?
Dang my loader is attached to those ports
This is my current setup. On the loader valve the PB port (red arrow) goes to one side of hydraulic block (red arrow)
The other port (yellow arrow) goes to other side of block (yellow arrow) return to sump is the other port. There is also another port marked "in"
/ Backhoe attachment #39
OK, I didn't realize it was plumbed that way. We also didn't know before that the FEL was already using the ports. So now we do. Ignore what I wrote before in #38 then.... I'll just delete that message to avoid confusion. t.
So... now I am wondering what the best way to go is. Frankly I'm not sure. What is needed here is a hydraulic schematic.
1.First things first. I don't understand why the OEM manual diverter output to the FEL goes into an unmarked port on the side of the loader control valve instead of to the port marked "IN". It could be as simple as it being an alternate "IN" port. I see a tag on the top of the loader control valve. Will that lead us to some more info on that valve?
2. And then there is the question of how to hook up the backhoe. It depends on if the BH control valve assembly also has a PB port. If so, then my thought would be to disconnect the hose (red arrow) currently running between the PB on the FEL loader valve and the hydraulic block. Disconnect the red arrow hose at the hydraulic block and run it to the "IN" on the Backhoe valve stack. Then run a hose from the PB port on the Backhoe valve stack back to the hydraulic block. Add a separate low resistance return line from the OUT port on the BH valve stack that goes to the sump.
When the backhoe is not mounted, either reconnect the hoses or have a jumper hose to replace the back hoe. In fact, something I hadn't realized until just now is that type of plumbing explains why those jumper hoses are so commonly used when swapping backhoes into an existing system. I learn something everyday.
3. What I don't like about that plan above is it relies on a PB on the BH control valve stack, and also we are sure putting a lot of obstacles that use up flow strength and all in the path of a small hydraulic pump to start with.
So... we need some hydralic schematic diagrams of these parts: FEL loader valve & the hydraulic block and probably the valve stack on the BH as well.
A PTO pump with reservoir is beginning to look better all the time.
rScotty
Well here it is. Picked it up today. He claims no top link used with this sub frame and he didn't have one hooked up ?
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
Snap-On Gold Medal Tribute to Excellence Limited Edition 3-Bay Tool Box (A63689)
Snap-On Gold Medal...
Stertil Koni 18000lbs Auto Lift Columns (A61572)
Stertil Koni...
John Deere TX Gator (A60462)
John Deere TX...
2860 (A56857)
2860 (A56857)
2018 VERMEER BC1000 XL PORTABLE WOOD CHIPPER (A63276)
2018 VERMEER...
