Backhoe attachment
/ Backhoe attachment #1
Keyote
1966 ford 3000
Ford 3000 onboard hyd. operating a backhoe attachment.
I expect it to be slow but will I need to install a PTO pump?
Thanks.
Jim
/ Backhoe attachment #2
Thanks.
Jim
What do you mean by onboard hydraulics??
Is this tractor equipped with a front end loader??
If so, it probabally has a pump on the front that powers it. Tap into that for the BH and it should be pleanty fast.
If it doesnt have a FEL, you are going to need a BUNCH of weight up there to offset the weight of the BH.
But to answer your question, NO you shouldnt need a PTO pump. BUT if you dont have a FEL or pump out front, it may be too slow for your liking and you may choose to add a PTO pump. But it certainly isnt a requirement.
/ Backhoe attachment #3
I would DEFINITELY try it on the tractor's hydraulics first.
Unless/until you get good at operating it and feel a "need for more speed" you will probably find the tractor's hydraulic flow and pressure to be adequate.
If the tractor already has a loader and if that works fine you should be OK to go onto that circuit (power beyond, etc.)
If it doesn't have a loader, perhaps there are rear hydraulic outlets ? those should be good enough - at least through your learning curve and modest projects.
If you haven't used a hoe before; SMALL BITES will usually work faster than large.
Don't just put the bucket 2ft from the edge and expect to cut straight down.
Nibbles, just take nibbles (-:
Thanks for the info.
I fabricated a ROPS that extends past the front of the tractor and have a quick detach
front grader blade I use. I can easily add more weight if needed.
I operate the blade with a 5 ton winch mounted on the extended ROPS.
My question now is gonna be purchasing the right Adapter plate and hoses etc.
Thanks for your advise!
Jim
2017 Peterbilt 320 T/A McNeilus 4029 28yd Front Loader Garbage Truck (A64556)
2017 Peterbilt 320...
2024 CATERPILLAR CP56B PADFOOT ROLLER (A65053)
2024 CATERPILLAR...
60in Forks (A64553)
60in Forks (A64553)
2014 Ford Expedition SUV (A64557)
2014 Ford...
2012 Kenworth T300 17ft. Cab and Chassis Truck (A64194)
2012 Kenworth T300...
2020 KUBOTA KX080-4 EXCAVATOR (A65053)
2020 KUBOTA...
