Backhoe attachment question
/ Backhoe attachment question #1
Jason37756
Huntsville, Tn
Kubota 2350, L 3400
Is it possible to use a backhoe attachment from a bobcat 610 on a tractor via a pto pump? Or is this a different pressure setup?
/ Backhoe attachment question #2
Should be fine, I have a case skid steer unit that is mounted to a subframe I use on my kubota with a PTO pump and tank. Just need to get a 540 pto pump with the correct GPM or the hoe will be slow if you get a low GPM pump.
Here is a picture of the inlet...weird symbols.
Bobcat Pallet Forks (A64127)
Bobcat Pallet...
2020 Westfield MKX 100-83 Auger with Swing Hopper (A61307)
2020 Westfield MKX...
Bobcat Pallet...
Kubota Diesel Utility Tractor (A62679)
Kubota Diesel...
2015 Ford F750 Service Crane Truck (A62613)
2015 Ford F750...
2018 Ford F-550 Altec AT37G 37ft. Insulated Bucket Truck (A64556)
2018 Ford F-550...
