backhoe attachment on skidder problem
/ backhoe attachment on skidder problem #1
hoyt351w
were in the process of trying to fit a regular size john deere backhoe attachment onto the back of my fathers 230 timberjack skidder. the problem that we have is where and how to run the hyraulic pump. the dealer says that out 30 GPM is too big to run off the front of the motor and we run the risk of snapping the crank shaft off. there is very little room on the side of the trans to run a PTO too. we were thinking about running it with a v belt arrangement or chain drive coming off the trans tailshaft. would the belts provide enough grip to drive the pump? how fast would the pump have to run to get the needed flow? any help would be great
/ backhoe attachment on skidder problem #2
/ backhoe attachment on skidder problem #3
I think the first thing we need to know is the backhoe attachment open or closed system,is the 30 gal pump off a backhoe if so what model?
the only reason i mentioned snapping the crank is because the dealer said that the crank is only rated for something like a 15 gpm pump.
and what exactly do you mean by an open or closed system
thanks
/ backhoe attachment on skidder problem #5
Most JD backhoes used a closed system and more than likely you will need more than the pump you have,take a pic of backhoe and pump and model # of the hoe or what TLB it came off of.
where would the id tag most likely be. i've looked for it before but couldn't see it
/ backhoe attachment on skidder problem #7
Where are you getting the 30gpm number from? How big is this backhoe attachment? For comparison, a John Deere 110TLB (43hp engine) only uses 16.3 gpm to run the backhoe portion (source)
Aaron Z
/ backhoe attachment on skidder problem #8
The plate if it has one should be on the valve plate cover if not take some pic's of the BH and the pump,do you know what the tractor model it came off of 300-400-500-etc JD ?
2019 FORD F-250 SUPER DUTY (A65643)
2019 FORD F-250...
2023 CATERPILLAR 259D3 SKID STEER (A64279)
2023 CATERPILLAR...
Kinze KPM3 Planter Monitor (A65640)
Kinze KPM3 Planter...
John Deere 1790 Planter (A66285)
John Deere 1790...
2023 Chevrolet Silverado 5500HD Auto Crane 6006EH 6,000lb. Crane Mechanics Truck (A64194)
2023 Chevrolet...
2011 UNKNOWN FRAC PUMP (A65643)
2011 UNKNOWN FRAC...
