Backhoe Backhoe...3 Point or Custom Subframe
/ Backhoe...3 Point or Custom Subframe #1
jgbanshee
PA
JD 310SE, 325G, 35G, 4300, 5300, 5210, 445, 450 Crawler, CAT D3B, Ford 2N, 7000, 5000, 4000su, 3610, 445D, 345C, 340B, 1100
I have a Ford 545C industrial tractor/loader. I am looking at getting a backhoe attachment for this tractor. The backhoes that I am looking at are the Bradco 609 and Woods 1050. These weigh around 1800lbs. The tractor weighs around 7000 lb or a little more. I know that the subframe system is much better for attaching backhoes. The catch is that neither company makes a subframe unit for my tractor. I do plan on doing some hard work with this unit but I am wondering if since the backhoe weighs so much that the 3pt hookup will be fine or will that make it worse.
/ Backhoe...3 Point or Custom Subframe #2
jg, anyone that I've ever talked to that had a 3pt hoe attachment seem like they were disappointed in its performance. I suspect you would be too. The 3pt hoes are just not that good of a set up. Maybe someone here that has one will shed some more light on the subject. I would go with a custom subframe set up even though it will cost more up front. You will have a more reliable rugged hoe. I was just thinking about checking into what would have to be done for a subframe set up for my JD 3520/cab tractor.Currently there is no hoe available for the cab tractors.
/ Backhoe...3 Point or Custom Subframe #3
Got any pics of the 3 point links?
/ Backhoe...3 Point or Custom Subframe #4
That size of tractor normally only gets a three-point hoe. Your tractor is of a completely different design as far as thickness of housings and durability of the three point when compared to compact tractors. That is the reason that a sub-frame isn't offered. You will have no problem using a three point hoe with this tractor but you do need to make sure that you get what ever lock down devise or attachments that the manufacture recommends for the hoe to attach to the tractor.
/ Backhoe...3 Point or Custom Subframe #5
I've use a Woods 1050 on my New Holland TN75D for about 4 years now. Jerry is right about 3pt hitches on larger tractors. They work fine. The mount on the 1050, even though it is 3 points, is a very rigid mount. I can tell no difference from the subframe mounts that I ran on my 3 previous backhoes. The Woods 1050 is an excellent hoe.
Andy
/ Backhoe...3 Point or Custom Subframe #6
jgbanshee,
Have you tried Bushhog brand backhoes? They are made here in Alabama and are very high quality. I have several Bushhog attachments and am very pleased with them. If you look at their website Bush Hog® there are 25 dealers in Pennsylvania that sell their backhoes. They have 3pth and subframe hook-ups available. Hope this helps.
Chris
2012 CASE CX350C EXCAVATOR (A65053)
2012 CASE CX350C...
2021 Chevrolet Silverado 2500 HD Royal Service Truck (A64194)
2021 Chevrolet...
2016 TAKEUCHI TB240 EXCAVATOR (A65053)
2016 TAKEUCHI...
New/Unused Wolverine 72in Tiller (A65583)
New/Unused...
2016 CATERPILLAR 926M WHEEL LOADER (A65053)
2016 CATERPILLAR...
INOP/NON-RUNNING 1957 B61 Mack (A65563)
INOP/NON-RUNNING...
