SPYDERLK
Super Star Member
- Joined
- Feb 28, 2006
- Messages
- 12,555
- Location
- VA
- Tractor
- JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
Im surprised no one addressed this speed issue. You are right. It is way too fast for those large bits. I really like the hole saw tricks mentioned to get a good hole. Thats definitely what Id do if constrained to the hi speed minimum you have on your press.Thanks for all the feed back. I never thought of a hole saw.
I was mostly concerned about the 700 rpm on my drill press.
It seems a little fast to me for a 1/2" hole so I was worried
about a 7/8" but I sounds like I should be OK.
If the hole isn't perfect nobody will notice - I cut all the steel
plate with a Sawzall. I clamped a couple of angles back to back
on either side of the cut line to use as a blade guide. Actually it came out
pretty good. Think I'll look for some cheap drill sets.
Thanks alot.
larry
