Back Yard Mechanic needs to Drill 7/8" Hole
   / Back Yard Mechanic needs to Drill 7/8" Hole #21
A trick (?) I do, is take a piece of 3/4" oak or other scrap of hardwood, using the hole saw first cut your hole in the wood. Then clamp the wood to the steel, using the wood as a guide (instead of the center pilot bit) has saved me many a broken or bent pilot bit. It also concentrates the cutting oil in the work area instead of throwing it all over the shop.
Maybe everyone else does this, but once I tried it, it has become standard practice for me wherever there is room for the clamps.
Bob
   / Back Yard Mechanic needs to Drill 7/8" Hole #22
I usually use a step drill for stuff thicker than 1/4 inch or so. Not the most sophisticated, but gets the job done.
I drill a pilot hole first (on the drill press, if possible), then I use a regular hand drill for the step drill bit and flip the workpiece over when I'm halfway through to drill from the other side. This helps keep the hole from being tapered.
You can get big (up to 1 inch or so) step drill bits at Harbor Freight pretty cheap.
If the hole had to be super-perfect, I'd probably use one of the other methods.
   / Back Yard Mechanic needs to Drill 7/8" Hole #23
Hi All,
I am building a road grader. It is a low (as possible) budget project.
I am not a machinist but have a lot of patience.
I have almost finished cutting all the steel pieces and will need to drill four
7/8" and two 3/4" holes in 3/8" material for the lift arms and top link pins.
It looks like two drill bits from McMaster_Carr will run me about $100 . Or I could just get the 7/8" bit and use a bushing on the 3/4" top link pin.
QUESTION:
My drill press has a 1/2 hp 1750 rmp motor. I get a 5:2 speed reduction
using my slow speed pully for 700 rpm. Can I drill a 7/8" hole with this??
Or is there a better (cheaper) way ?
Thanks.
7/8" Hitachi S & D with a 1/2" shank at Lowe's is around $19. Low speed and cutting oil works great for me...be patient so as not to "work temper" the bit...I've been using the same one for a couple of years now.
   / Back Yard Mechanic needs to Drill 7/8" Hole #24
Also, when using large bits, drill a pilot hole, or two.
For a 1" hole, in thicker steel, rather than bite it off all in one operation, I tend to drill a 1/4" pilot hole, then enlarge to 1/2", then up to 1".
In 3/8" thick steel shouldn't be too much trouble, but I'd still drill a pilot hole before moving up to the 7/8" solid bit.
Your drill press will handle it. take is easy, keep it cool, and don't use excessive down pressure. Let the bit do the cutting.
   / Back Yard Mechanic needs to Drill 7/8" Hole #25
Most step drills are only designed for metal less than the dept of the steps.
Not that they wont work but when they first came out they were for sheet metal like electrical panels.
tom
   / Back Yard Mechanic needs to Drill 7/8" Hole #26
Bob
Great idea! Leaving a "well" for the cutting oil is good, useful info...I'll try it.
   / Back Yard Mechanic needs to Drill 7/8" Hole #27
I don't know why the winshield wash works but it does, My uncle told me about it and after trying it I have never used cutting oil since. It is cheap and it doesn't make nearly the mess as oil on parts that need to be painted later. I have a quart spray bottle that hangs right on the drill press. Works with twist bits as well.
I too have terrible luck with large bits. I work for a commercial fabrication and erection company and we use Hogan Drills (magnetic drill) and Milling bits, or an iron worker with punch. At home I use the hole saws or bring home a hogan.
What are the advantages of using windshield washer fluid as a lubricant? I've heard of using ATF, but this is the first time I remember anyone suggesting washer fluid.
I've not had good luck with large, cheapo drill bits. Seems like I ruin them pretty quickly.
   / Back Yard Mechanic needs to Drill 7/8" Hole #28
add another thumbs up for the HF big drill bits. i have been using mine for years, and they hold up extremely well for the price. definitly one of the better items at the store.
HF s&d bits=HF impact sockets
mine easily and repeatedly cut holes in 2" stock while building my wood splitter.
   / Back Yard Mechanic needs to Drill 7/8" Hole #29
Thats what I was gonna reccomend..For less then the cost of the bits and in less time then it took me to type this reply you'd have all your holes punched....Just find a fab shop, prep everything by marking your holes, etc... and 98% of these shops will do this kind of work for beer money. They may not do it right on the spot, but if you can drop off the parts and pick them up later there should be no problem.
   / Back Yard Mechanic needs to Drill 7/8" Hole #30
When I built my 8' grader I had to drill 16 holes to mount the blades and also drill the mounting holes for the hitch. That is 16) 3/4-7/8 holes in 1/2" flatbar and 5/8" for the hitch, I used a pistol drill and holesaw bit to do this. Much easier than using a twistedshank bit IMHO. What saved me the most time was having a couple of small cnc bits to drill the pilot holes with 1/8" approximately. While I have a drill press the work was to large to hold in place to use it, I was very suprized how well the holesaw worked, took about 1.5 hours to do about 20 holes.
   / Back Yard Mechanic needs to Drill 7/8" Hole #31
I always thought those hole saws were strictly for wood, just by looking at the teeth on them. I never dreamed that you could drill holes in thick steel until i read this. I can't wait to try it out.
The holesaws for wood have no markings if I remember correctly, the ones for metal are normaly marked bimetal,I remember one time cutting a large hole in some 1/2" aluminium plate with a normal wood type holesaw, it took quite awhile,with my small tabletop drill press, it was toast when I finished,I didn't use no lube/oil just wanted to see what the difference was, now I all my holesaw sets are bimetal, you can still use these for wood as well>> Ampa :)
   / Back Yard Mechanic needs to Drill 7/8" Hole #32
I like to use bridge or car reamers. You can get them in 1/2" shank or morris taper. You need to drill a starter hole around 3/8 and let the reamer do the rest with a hand drill. Use lots of oil. I found all the ones I use on e-bay for next to nothing.
Dan
   / Back Yard Mechanic needs to Drill 7/8" Hole #33
Don't try to use an intermediate bit such as 3/8" or 1/2".
What is the reason for not using an intermediate bit? I usually use a 1/2" or 5/8" after a 1/8" or 3/16" pilot hole when drilling 7/8"or 1" holes. I'm always willing to learn something new.
The windshield washer fluid works because the bits need a coolant, not a lubricant. If you don't clean up the fluid and maybe apply oil to the table, it might rust up on you. Even the column on my drill press will rust if I don't oil it occasionally.
   / Back Yard Mechanic needs to Drill 7/8" Hole #34
Seems to me step drills are close to these sizes, they will drill thro 3/8 plate, you may have to come from both sides of the plate and a 3/8 drill will easily do this
   / Back Yard Mechanic needs to Drill 7/8" Hole #35
Four pages on how to drill a small hole:laughing:
Come on SPRING 2010:thumbsup:
   / Back Yard Mechanic needs to Drill 7/8" Hole #36
There are some relatively new types of hole saws out now that are more like a machine tool than a hole saw. they mount about the same way as old style hole saws on a col let and are becoming very popular in electrical shops for cutting holes in panels. They work great in just about anything though you need to make sure you clear the teeth when drilling deeper than the tooth is. (Tooth is about 3/8" high in bits above 1" and 1/4" in those below 1") they have much larger flat teeth that do not have a Kerf in them but the cutting edges from tooth to tooth changes from a point on the inner ring to a point on the outer ring area.
they come in 1/16 increments from 1/2" up. Costs are probably 20 bucks for Collete and 15+ for the bits. We use the heck out of them where I work, I've punched a 1-1/4" hole through 1" plate by drilling from both sides, it ends up looking like a machined surface cut... We use them in 18V Bat Drills
I wish I could remember the names of them I'm thinking Jacobs might have something to do with them.
http://www.grainger.com/Grainger/items/1FAH9?Pid=search
http://www.grainger.com/Grainger/items/1XRN8?Pid=search
What we use is sort of a combination of these two bits and works great
Mark M
   / Back Yard Mechanic needs to Drill 7/8" Hole #37
I bought a torch last autumn and this makes the effort to salvage parts from wrecked machinery, a whole lot easier.
I cut some DOM tubes off an old silage feeding box, cut parts of it to length, torched holes in the plates and welded these DOM tubes in..
I only used the hole saw for positive markings to where i need to torch... ;)
   / Back Yard Mechanic needs to Drill 7/8" Hole #38
I've used an arc welder with a small rod to burn out holes for a cat 1 pin. If you've got an arc welder that is. With a little file work the collar on the pin hides the imperfect hole. I've got a drill doctor that will sharpen bits up to 3/4" so I hate to spend money on a bit I'd have to take somewhere to have sharpened such as the 7/8 needed for the cat 1 pins.
   / Back Yard Mechanic needs to Drill 7/8" Hole #39
As mentioned HF has the Silver & Demings drill set and step drills that drill up to 1 3/8". I have both and have not had any problem with either and the price was right.
   / Back Yard Mechanic needs to Drill 7/8" Hole #40
Learn to sharpen your own bits on a bench grinder, its not hard.
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A59905)
2020 INTERNATIONAL...
2009 Kubota M108S (A60462)
2009 Kubota M108S...
2365 (A60432)
2365 (A60432)
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A60430)
2006 TRAIL KING...
2019 GALYEAN 150BBL STEEL (A58214)
2019 GALYEAN...
2019 CATERPILLAR 950M WHEEL LOADER (A60429)
2019 CATERPILLAR...
