Back tires skid when in four wheel drive?
   / Back tires skid when in four wheel drive? #1
CobyRupert
Super Member
Washington County, NY
JD 5075E
Tractor runs fine. I put new tires on tractor. I order the same exact size as before, but ever since, the back tires seem to skid when I engage 4WD. Is this a problem with transmission?
Also: I want to use tractor to snow blow. Should I put chains on the front tires or back tires?
   / Back tires skid when in four wheel drive? #2
Ha! Cup holder doesn't work right either.
Oh, is it the cup holder? Good point. I thought it might be the cup, because it only holds about 75% of what it normally did without spilling over.
   / Back tires skid when in four wheel drive? #4
Somebody went to a LOT of work to set that picture up!!!!
   / Back tires skid when in four wheel drive? #5
Return your trays and seatbacks to the upright position in preparation for takeoff.
   / Back tires skid when in four wheel drive? #6
At least you’ll be sitting level when going down hills.
   / Back tires skid when in four wheel drive? #7
New apprentice at the tractor repair shop..! Was told to put the big tires on first..
   / Back tires skid when in four wheel drive? #8
Na, the tire jockey screwed up,
he was supposed to set it up for sidehill work,
not downhill work.
2016 Poulan Pro PP19A42 42in. Riding Mower (A49346)
2016 Poulan Pro...
SpotWeld RockerRite 480V Arm Type Spot Welder (A50322)
SpotWeld...
2017 UTILITY VS2RA 53FT REEFER TRAILER (A51222)
2017 UTILITY VS2RA...
2008 Ford E-250 Cargo Van (A50323)
2008 Ford E-250...
2016 FREIGHTLINER CASCADIA TANDEM AXLE 6X4 MID ROOF SLEEPER TRUCK (A51219)
2016 FREIGHTLINER...
CASE 850M WT CRAWLER DOZER (A51242)
CASE 850M WT...
