Back tires skid when in four wheel drive?
   / Back tires skid when in four wheel drive? #1
CobyRupert
Super Member
Washington County, NY
JD 5075E
Tractor runs fine. I put new tires on tractor. I order the same exact size as before, but ever since, the back tires seem to skid when I engage 4WD. Is this a problem with transmission?
Also: I want to use tractor to snow blow. Should I put chains on the front tires or back tires?
   / Back tires skid when in four wheel drive? #2
Ha! Cup holder doesn't work right either.
Oh, is it the cup holder? Good point. I thought it might be the cup, because it only holds about 75% of what it normally did without spilling over.
   / Back tires skid when in four wheel drive? #4
Somebody went to a LOT of work to set that picture up!!!!
   / Back tires skid when in four wheel drive? #5
Return your trays and seatbacks to the upright position in preparation for takeoff.
   / Back tires skid when in four wheel drive? #6
At least you’ll be sitting level when going down hills.
   / Back tires skid when in four wheel drive? #7
New apprentice at the tractor repair shop..! Was told to put the big tires on first..
   / Back tires skid when in four wheel drive? #8
Na, the tire jockey screwed up,
he was supposed to set it up for sidehill work,
not downhill work.
2003 - 1890/1910 Air Seeder and Air Cart (A51039)
2003 - 1890/1910...
2012 Geringhoff NS1200 Corn Head (A50657)
2012 Geringhoff...
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A51039)
John Deere 5090E...
Toro Workman Cart (A50322)
Toro Workman Cart...
THE ROOTSTER STUMP & ROOT PICKER (A51243)
THE ROOTSTER STUMP...
