Back tires skid when in four wheel drive?
   / Back tires skid when in four wheel drive? #1
CobyRupert
Super Member
Washington County, NY
JD 5075E
Tractor runs fine. I put new tires on tractor. I order the same exact size as before, but ever since, the back tires seem to skid when I engage 4WD. Is this a problem with transmission?
Also: I want to use tractor to snow blow. Should I put chains on the front tires or back tires?
   / Back tires skid when in four wheel drive? #2
Ha! Cup holder doesn't work right either.
Oh, is it the cup holder? Good point. I thought it might be the cup, because it only holds about 75% of what it normally did without spilling over.
   / Back tires skid when in four wheel drive? #4
Somebody went to a LOT of work to set that picture up!!!!
   / Back tires skid when in four wheel drive? #5
Return your trays and seatbacks to the upright position in preparation for takeoff.
   / Back tires skid when in four wheel drive? #6
At least you’ll be sitting level when going down hills.
   / Back tires skid when in four wheel drive? #7
New apprentice at the tractor repair shop..! Was told to put the big tires on first..
   / Back tires skid when in four wheel drive? #8
Na, the tire jockey screwed up,
he was supposed to set it up for sidehill work,
not downhill work.
SCAN TO RECEIVE TEXT UPDATES (A51242)
SCAN TO RECEIVE...
(2) ROLLS OF HD CHAIN LINK MESH WIRE (A50460)
(2) ROLLS OF HD...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A49461)
2021 Ver-Mac...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2012 Ford F-250 4x4 Ext. Cab Pickup Truck (A50323)
2012 Ford F-250...
2019-2024 Dodge Ram Front Bumper (A49461)
2019-2024 Dodge...
