Back hoe fluid of choice...
   / Back hoe fluid of choice... #1
Frankman
Erie Co. PA
None yet
Just finishing up a repair on my Woods Bh9000 and need to change the fluid and filter.. I can not find any solid info as what to use for fluid, and can not find a filter part #... Anyone have one, or a manual that would mind sharing the info? Thanks
It has a pto pump. Doesn't use tractor hydraulics.. Sorry forgot to post up that info.
   / Back hoe fluid of choice... #3
i put a store brand utf in my 6500 hyd tank. napa had my hyd filter.. crossed from the one that was on it. was a common one that I recall
   / Back hoe fluid of choice... #4
woods part number is 62421 for the filter, according to the manual on the pump kit..
   / Back hoe fluid of choice... #5
The manual for my BH7500 calls for:
SAE Hydraulic Transmission Fluid - All temperatures
Type "A" or "AF" ATF - All temperatures
SAE 30-30W - 90° F and above
SAE 20-20W - 35° F to 90° F
SAE 10-10W - 35° F and below
The BH9000 pump should be the same...
Thanks guys. I went and got a purolator filter and some fluid.... Not sure how many gallons I needed so I picked up 10.
LOT LOCATIONS (A52576)
Bobcat T650 Skidloader (BURNT) (A50774)
Bobcat T650...
New in Crate 20' x 40' Hoop Building (A50515)
New in Crate 20' x...
2016 Chevrolet Cruze Sedan (A50324)
2016 Chevrolet...
Kivel 3500 Lb Pallet Forks (A50121)
Kivel 3500 Lb...
