Back hoe fluid of choice...
   / Back hoe fluid of choice... #1
Frankman
Erie Co. PA
None yet
Just finishing up a repair on my Woods Bh9000 and need to change the fluid and filter.. I can not find any solid info as what to use for fluid, and can not find a filter part #... Anyone have one, or a manual that would mind sharing the info? Thanks
It has a pto pump. Doesn't use tractor hydraulics.. Sorry forgot to post up that info.
   / Back hoe fluid of choice... #3
i put a store brand utf in my 6500 hyd tank. napa had my hyd filter.. crossed from the one that was on it. was a common one that I recall
   / Back hoe fluid of choice... #4
woods part number is 62421 for the filter, according to the manual on the pump kit..
   / Back hoe fluid of choice... #5
The manual for my BH7500 calls for:
SAE Hydraulic Transmission Fluid - All temperatures
Type "A" or "AF" ATF - All temperatures
SAE 30-30W - 90° F and above
SAE 20-20W - 35° F to 90° F
SAE 10-10W - 35° F and below
The BH9000 pump should be the same...
Thanks guys. I went and got a purolator filter and some fluid.... Not sure how many gallons I needed so I picked up 10.
2014 KENWORTH W900 MID-ROOF SLEEPER (A50854)
2014 KENWORTH W900...
Fifth wheel multi use trailer. (A51039)
Fifth wheel multi...
PORTER CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTER CABLE 150...
2011 John Deere 844K Articulated Wheel Loader (A50322)
2011 John Deere...
2013 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A51039)
2013 Doyle Dry...
2012 PETERBILT 388 NATIONAL CRANE TRUCK (A50854)
2012 PETERBILT 388...
