Back Hoe Arm to fast
/ Back Hoe Arm to fast #1
RandyHut
Piqua, OH
Mahindra 2816
My backhoe arm that raises and lowers the bucket moves to quickly when the lever is moved, is there an easy way to slow it down? All else works fine, just this one cyclinder.
/ Back Hoe Arm to fast #2
what engine rpm are you running?
/ Back Hoe Arm to fast #3
Either use a restrictor in one of the fittings or use an adjustable needle valve to adjust the flow to your needs.
This needle valve will restrict in one direction and allow full flow in the other direction.
3/8 NPT 8 GPM PRINCE WFC-600 IN-LINE FLOW CONTROL
One kind of restrictor looks like a washer with a hole in it.
/ Back Hoe Arm to fast #4
That is what you use the levers for, to feather the flow by just opening the valve enough to move at the speed you want. If it is too fast, throttle back and/or don't pull full back on the lever when raising. I sure wouldn't put in any restriction device as when you learn proper operation, you may want it to move faster.
If you are feathering the control valve a bit and it still moves too rapidly, you may have a bad valve also that only opens fully or fully closed. I have never seen one do that, but it may be possible I suppose.
/ Back Hoe Arm to fast #5
Agree with Gary Fowler. This topic comes up regularly. When you are accustomed to the machine it will seem too slow. The other thing you can do is use two functions at the same time - stick and swing or stick and bucket.
/ Back Hoe Arm to fast #6
Just reduce the engine rpm and the pump flow will decrease,, and therefore speed of operation.
/ Back Hoe Arm to fast #7
that's why I asked what rpms he's running at. I have the same tractor except the 30 version and I don't notice any problems like he's experiencing.
I run it at about 1800 rpms.
/ Back Hoe Arm to fast #8
How many hours of use do you have on the hoe? As stated reducing the amount of movement of the lever and RPMs will slow the motion of the dipper stick, (attached to the bucket); and same with the boom, if that is what you were referring to moving too fast.
/ Back Hoe Arm to fast #9
He only has 7.8 GPM pump flow, so 1/2 or 1/3 rpm would produce about 3.9 or 2.6 GPM's. .
/ Back Hoe Arm to fast #10
Years ago when I first got my backhoe, I read (I think on this forum) that a good training process is to fill the bucket with water and move it around without sloshing the water all over the place.
Being near a lake, this was pretty easy for me to do so I got to play/practice with movements and control using someone elses water!!
/ Back Hoe Arm to fast #11
That is what the levers are for. You don't have to push them to the max. You just barely move them if you want to move slow. My grandpa has a old Kubota F2550 that the loader valve is worn out on it is all or nothing.
RPM is 1500 - all the other cylinders work as i would expect just the cylinder that raise the main boom is the one that is so quick that it is jerky. i will look at all the linkage on the handle and see if something is worn or sticking.
Thanks for the ideas
2016 GMC SLT 3500 Pick Up (A62613)
2016 GMC SLT 3500...
2022 EZ-GO ELITE...
2021 Gatormade Lowboy Trailer (A62613)
2021 Gatormade...
2020 Chevrolet Tahoe SUV (A64194)
2020 Chevrolet...
2010 CATERPILLAR 320DL RR EXCAVATOR (A60429)
2010 CATERPILLAR...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
