Back dragging: how aggressive?
/ Back dragging: how aggressive? #51
I did a lot of back dragging today, smoothing up a site for a new greenhouse. But I'm always cautious because the cylinders are so extended in dump direction, and would be prone to buckling.
HOW conservative, though? Getting the bottom of the bucket vertical and dragging in a moderate gear with the front wheels held up by the bucket, well, that is very aggressive, I suppose asking for trouble.
But putting the bottom of the bucket, say, 20 or 30 degrees from vertical, and dragging in the lowest gear, is that too aggressive?
Where do you draw the line?
I too tend to back drag a lot, but I do it not with the bucket other that a slight angle less that level, and then I do it more with my FEL in the float position. That way the only down pressure is from the weight of the bucket alone.
/ Back dragging: how aggressive? #52
You or anyone else doesn't know where that line is drawn. Keep doing what you are doing, and hope you do not find out.
/ Back dragging: how aggressive? #53
Get a box blade
You bought that box blade for a reason...use it.
A box blade would have been way better for this job, but I don't have one! And I did consider getting one just for this, but couldn't convince myself it was a good move, considering the cost. If I ever do another job that could use a box blade, I'll regret that.
/ Back dragging: how aggressive? #55
No, some jobs should be hired out. And some jobs will not lend themselves to doing them with your subcompact tractor. Nothing wrong with that.
/ Back dragging: how aggressive? #56
Why risk damage. I reverse my 1000# Rhino rear blade 180 degrees and lower to the ground. Then I go like smoke and oakem.
2019 FORD F-150 STX CREW CAB TRUCK (A59823)
2019 FORD F-150...
2016 PETERBILT PB337 FLATBED TRUCK (A52706)
2016 PETERBILT...
2010 Honda Accord Sedan (A59231)
2010 Honda Accord...
Little Wonder Debris Vacuum (A59228)
Little Wonder...
2014 Magnum 7696BLA Light Tower (A59213)
2014 Magnum...
2016 26ft T/A Dovetail Flatbed Equipment Trailer (A59228)
2016 26ft T/A...
