Dirt Moving Back dragging dirt with FEL
   / Back dragging dirt with FEL #21
Back dragging with the bucket pointed down isnt a big deal. But the general rule I think is dont angle it down more than 45 degrees. This limits the chances of catching something, and minimizes the amount of rod sticking out of the cylinder and lowers the chances of bending it.
You DONT want to dump the bucket all the way, and then do what you did. Good way to pop hydraulic hoses or bend cylinders.
But I gotta ask, why not push the dirt back into the holes instead of dragging?? The tractor pushes way better than it pulls.
Well I have been known to do things wrong, maybe aggressive backdragging is one of them. I wouldn't do it in hard or rocky ground where it feels and sounds bad. But an example would be clearing weeds and brush up close to a building. Pulling the blade backward at the vertical or slight angle one way or the other scrapes the stuff off while not disturbing the soil. And you can work within a few inches of the building. Going forward to do the same work does not work as well, at least for me, at removing the weeds and leaving the dirt. Also going forward on rubber tires the machine will move side to side too much for safely working right up to the building. It is easier with the blade on the ground going backward. There are other examples. I think small backhoes get used for lots of things to avoid hand labor or where a more specialized piece of equipment might be better. But, I do take that point about how some practices might abuse the equipment.
   / Back dragging dirt with FEL #22
I think the key here is you have to use "common sense" to not abuse your machinery, yet the machinery is made to use. You as the operator will have to make that determination as to what is abuse and what is use. If you have limited experience and wind up breaking your machinery, then you will hopefully learn from that and do better next time. When things look and sound "rough" then back off and try doing the job some other more sensible way.
James K0UA
   / Back dragging dirt with FEL #23
I don't agree, the tractor is a much better pulling machine than a pushing. That said I back drag with my tractor all the time. If it can't handle it I'll get one that will.
Wrong. In the context of this thread, pulling in reverse with the FEL down is worse than forward with the FEL down.
We aint talking about pushing with the front vs pulling from the rear here.
   / Back dragging dirt with FEL #24
I'm guilty your honor.
As always - the TBN Brethren has graciously pooled their many years of experience, opinions and insight to help out a relative newbie! I truly appreciate all of the posts so far but the more responses the better!
   / Back dragging dirt with FEL #26
Anyone ever force the lower bucket locking pins to pop loose while back dragging? Seems to me to be a lot of stress on something that is designed for the opposite direction.
   / Back dragging dirt with FEL #27
I have thought of that. But it is never happened. So far!
James K0UA
   / Back dragging dirt with FEL #28
No hasn't happened yet,
What I think maybe mis described is that a relief valve will open once the FEL controls are left in their at rest positions.
Unless I am mistaken the relief only relieves pressure in relation to the pump and cylinders while using the controls are in use NOT the line or cylinder pressure once the FEL controls are in their at rest positions... I could be wrong
Maybe JJ or someone else can shed some light on this aspect??
   / Back dragging dirt with FEL #29
B21 has through-pins on bucket. Looked at quick attach adapters. Seemed to me they might not be compatible with backdragging, so never got one.
   / Back dragging dirt with FEL #30
Just remember that most of us do not have the TLB (tractor/loader/backhoe) that is designed for this (like a commercial backhoe with loader) that is built to take a beating everyday. I have used my CUT (compact utility tractor) back dragging with FEL (front end loader) but take it slow and am careful. I don't like to do it because I love my tractor and don't want (can't afford) an expensive repair bill.
Make sure bolts are torqued properly and inspect for cracks if you are doing this to reduce risk. With the stresses, anything not up to snuff will be a weak point for sure..
2014 Gravely 60" Zero Turn mower (A55973)
2014 Gravely 60"...
2015 Ford Escape SUV (A56859)
2015 Ford Escape...
20 UTILITY TRAILER (A58214)
20 UTILITY TRAILER...
3 Row Twin Row Renaldo Planter (A53317)
3 Row Twin Row...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A56435)
2017 Yale GLC050VX...
2015 Ford E-350 Cutaway Van (A55973)
2015 Ford E-350...
