Dirt Moving Back dragging dirt with FEL
   / Back dragging dirt with FEL #31
No hasn't happened yet,
What I think maybe mis described is that a relief valve will open once the FEL controls are left in their at rest positions.
Unless I am mistaken the relief only relieves pressure in relation to the pump and cylinders while using the controls are in use NOT the line or cylinder pressure once the FEL controls are in their at rest positions... I could be wrong
Maybe JJ or someone else can shed some light on this aspect??
That is right...the relief is between the pump and the SCV's. There is nothing to relieve pressure once the spools are centered. Furthermore, there are usually load checks built into the SCV's also that would prevent relieving back into the pressure port....no matter what position the SCV's are in.
   / Back dragging dirt with FEL #32
Back drag all the time. Rough it out often with the front end light. Uncurl the bucket slightly pulling back until it's fairly smooth. Then, to pack it down I'll curl the bucket all the way with slight/medium down force going forward. Works very well, never had a problem.
   / Back dragging dirt with FEL #33
My owner's manual warns not to back drag with the bucket curled forward at an angle greater than 15 degrees. If the cylinders are fully extended, and too much down pressure applied; you are tempting fate. Eventually you can bend or break a rod. If your tractor is under warranty, sorry, it won't be covered.
   / Back dragging dirt with FEL #34
I regularly push to backfill and do general grading but find it necessary to back drag due to space limitations, such as working at a tree line.
2018 Kubota U17 (A53317)
2018 Kubota U17...
3ft Metal 5-Point Star Art (A55853)
3ft Metal 5-Point...
UNUSED FUTURE FT-ZP20 20' X 30' GARAGE CARPORT (A57193)
UNUSED FUTURE...
Year: 2014 Make: Volkswagen Model: Passat Vehicle Type: Passenger Car Mileage: 135,272 Plate: Body (A56859)
Year: 2014 Make...
ST205/75R15 Trailer Tires (A55788)
ST205/75R15...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
