Back Blade Skids
   / Back Blade Skids #11
The ones on my blade are 6" in dia and the vertical post is 2" solid steel. I am glade that I have mine. If they don't do any good, then the ground is to soft. No you don't have to have them, but they make things easier IMO. Oh, and mine were $200 a pair. :mad:
   / Back Blade Skids #12
MtnViewRanch; Any chance of a closeup of the skid and mounting? Is there a web site selling the skids?
Thanks
   / Back Blade Skids #13
Thanks
Couldn't get a close up until Sunday. :( Don't know of any website that sells them. They need to be purchased from an implement dealer as far as I know. I do know that they are not the same price from all the manufacturers, but then again they are not all built the same either.
   / Back Blade Skids #14
I have read about people using steel sch40 pipe cutting a slot in it and putting bolts through where your bit attaches
Dont know how well it works but it would not sink if the ground is soft and a stick of 3" sch 40 ought to be around $100 for 10'(brand new price) and you could also use w/ crowned driveways.
   / Back Blade Skids #16
This is what I've done to my back blade for snow removal. The skid shoes are very heavy. The posts are 3" solid steel. The cost me $200 from the shop I bought the blade and tractor from. I haven't had a chance to try them out yet. Maybe today. I do know that on soft, not frozen gravel, the shoes will dig in. That is why I installed the pipe over the cutting edge of the blade.
   / Back Blade Skids #17
gregbkh: did you look at the hydraulic tail wheel for your blade; that's what I use to keep from digging when using it to clear snow on my gravel drive
   / Back Blade Skids #18
I built a pair of skid shoes that bolt through the cutting blade bolts on each end of the blade. Quick, cheap, and a little green paint. Nothing fancy.
I put a piece of 1/4" stock on the bottom of the shoes. This is below the cutting edge of the blade by that much. And is a replaceable, sacrificial foot.
Tried it out the first time today with about 6" of new fluffy snow.
Ground isn't frozen , or frozen very deep yet.
Worked well.
Good luck
   / Back Blade Skids #19
jobguy, here are some close ups of my skid shoes. I was wrong about the 2" solid stock, they are 2 1/2" solid stock with the outside of the sleeve being 3" dia and the shoe is 1/2" stock 6" dia.
   / Back Blade Skids #20
What I use on my blade is a couple of 2" heavy wall pipe caps with a stud welded into them and a nut welded to my blade. I double nut the stud on the blade. It gives me independent adjustment for each side.
2013 Ford Focus Sedan (A50324)
2013 Ford Focus...
2012 Ford F350 Bucket Truck (A47384)
2012 Ford F350...
RIGID TOOLBOX (A52472)
2017 KENWORTH T4 CONCRETE MIXER TRUCK (A51243)
2017 KENWORTH T4...
2012 Cottrell EZ-4807 22.5 Ton Car Hauler Trailer (A50323)
2012 Cottrell...
Year: 2011 Make: Ford Model: Crown Victoria Vehicle Type: Passenger Car Mileage: Plate: Body Type... (A51694)
Year: 2011 Make...
