Back Blade Skids
   / Back Blade Skids #1
JimBinMI
Coldwater, Michigan
2014 Kubota BX25D-1, 2014 Kubota BX1870
Has anyone attached skids/runners to their backblade to have it act more like a snow blade? I think that I would like to do this and have some ideas, but it would be great if someone already has done it and can attach photos, plans, etc.
I currently use the blade in reverse with the blade cupped toward me. Works OK.
Thanks, JimBinMI
   / Back Blade Skids #2
That would be interesting to see, the only thing that I've ever seen was a truck mounted snow plow adapted to the back of a tractor. I had the fun of checking out my neighbors B2710 with back blade the other day, he had 22" of the white stuff in his drive way, decided to get a 60" landpride back blade since his plow truck was out of commision. I was surprised how well the snow pushed consdering he doesn't have his turf tires loaded and has no chains, just went at it with the tractor in 4x4. The snow was a mix of powder on the top with wet stuff and ice down below. He managed to scrape his drive way down to bare concrete and push the snow several feet back into the yard, only bummer is this coming spring will be yard repair time.
   / Back Blade Skids
msocko3,
That's why I want skids! I have a gravel driveway and lawn that I push the snow onto, I want less gravel on the lawn and less lawn torn up. I think that I'll show a picture of some skids that I got off the internet to our Welding teacher at school and see if he can come up with something.
You're right, it is amazing what 4x4 will do in pushing snow, I too have turfs but I just got the rears filled with rim guard.
JimBinMI
   / Back Blade Skids #4
I just bought a 7ft woods back blade for plowing and I ordered the skid shoe package along with it. Price was a little steep ($135) but the skids are heavy duty and are shaped just like the ones you see on a truck plow. (Picture an upside down mushroom) I have them adjusted so the blade is held about 3/4 inches above the surface. They adjust with collars and large washers so you have a pretty good control over the height. My driveway is paved but I have some gravel area down to the barn which is why I opted for the shoes. If your gravel is really loose (like mine) the shoes won't work great because they still sink into the gravel but if you have a good packed bed made from running crush they would work well. (I have to keep my gravel loose because I need water to be able to run through it from a swale I put in front of the barn. Thats why I used #2 stone as opposed to running crush. Makes blading snow a little tricky but all I have to do is keep the blade raised a little) I considered having a set made but I don't have any welding/metal working tools myself and don't think I would have saved all that much to have them done.
Sorry no picture - no digital camera yet. Maybe Santa will be good this year!!
   / Back Blade Skids #5
A little different way to deal with this problem is if the tractor has draft control to set it light. As soon as the load increases ie: getting in the dirt it will lift the blade for you.
   / Back Blade Skids #6
I put some pickup truck snow plow skids plate (they look like an upside down mushroom) on my 7' 3 point hitch back blade last year. Used 'em once, and haven't used 'em since. They didn't work well for me on my crowned gravel driveway. I found that in order to minimze the amount of gravel I was plowing up I had to set the skid plates down so low that on flat ground it hardly looked like I was plowing any snow at all! I have much better luck by simply controling the height of the blade by using the 3 point lift lever.
   / Back Blade Skids
corm,
The ones that I think I'm going to try look more like little skiis. The upside down mushroom ones just look like they would work on a hard surface.
JimBinMI
   / Back Blade Skids #8
JimBinMi - A buddy of mine tried those last year and said they worked well on his gravel driveway. I've thought about trying them myself, but I think my biggest problem is the crown in my driveway. Having the crown makes it tough to plow, but grading my driveway flat to ease the plowing problem would allow the spring run-off to take away a bunch of my gravel.... no easy answer. Oh the challenges of living on the side of a mountain....
   / Back Blade Skids #9
Jim, I have some factory skidshoes for my Landpride backblade. They cost an extra $100/pair (inc. blade brackets) and are worth every penny. Easy to put on and off. They let me plow snow on my gravel drive without scraping off the gravel. They can also come in handy for grading gravel, but not quite as good as using guide wheels.
   / Back Blade Skids #10
I went on line at LandPride to look at your skid shoes. What diameter are they?
I could use a pair not only for snow but dirt. Do you think they are strong enough for dirt?
Thanks
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2017 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2017 Ford F-150...
1996 Generac 95A 023595 (A47384)
1996 Generac 95A...
2019 KOMATSU WA380-8 LOADER (A51242)
2019 KOMATSU...
International Tractor w/Belly Mower (A50774)
International...
