Back blade for snow removal
   / Back blade for snow removal #31
Another point that hasn't been mentioned is that when I am going forward with the rear blade set at an angle, if I put it at too sharp an angle it will actually push the rear of my tractor sideways. My rear blade has limited angle settings, but I have to find just the right angle that allows the snow to slide off without pushing the back end sideways.
I pretty quickly learned to load the front end loader with snow to give my front wheels better grip (R4 tires with no chains). Wet snow is much better than dry snow - weighs more for sure.
Also, just to be clear for the original poster, I usually just drive over the snow - forward - to let the rear blade do its work. If the snow is so deep that I can't driver over it without wheels spinning even in mechanical 4WD, then I'll use the front end loader to move the snow and then clean it up with the rear blade. Moving snow with the front end loader can be a tedious process compared to the rear blade. Scoop, backup, angle off, dump, repeat ... a lot! Still, any time on the tractor is a great thing - until the cold weather soaks in.
I've been noodling getting a front-mount snow blade, but so far just can't justify the cost. Plus, I'd prefer to keep the front end loader on the tractor during the winter months - well all the time. I know that they make snow blades that go on the FEL's quick attach. I'm noodling that too. Again, so far I've not pulled the trigger, mostly due to the costs.
Finally, as others have mentioned, using the rear blade with the cutting edge backwards does real well on gravel and even lawn (my own use). I don't need to do that a lot, so I'll usually do that very carefully (gently) by just driving the tractor backward. I've read that this presents a risk of bending the three point hitch arms or other parts. So far this has not happened. I try to be gentle about it. If you need to do that a lot then you're best to spin the rear blade around and drive forward with the cutting edge of the blade facing "backward".
Why if the snow is too deep do you use the loader? It is much faster to turn the back blade backwards and push that way. Also I drilled a couple of extra holes so I can angle my blade when it is turned backwards to make it easier to guide the snow. I make piles 6' high with my back blade as the tractor packs it as you drive on it so you just keep going up.
   / Back blade for snow removal #32
I壇 love to see a photo of the pipe on the cutting edge. I use the rubber horse stall mat between the cutting edge and moldboard trick. Works well but could dig a little deeper.
Looks funny after I plow. The rubber works like a squeegee to keep the cutting edge out of the gravel (1000 ft). Snow on the drive is as smooth as buttercream frosting!
You know I tried the horse stall mat and it worked OK, but I didn't like it as much as the pipe so I went back to that. I think both are good solutions though. I felt like the pipe scraped the snow better when very cold and disturbed the gravel less when warmer/wetter. Here's a pic of my setup -- I did it this way to make the pipe easily removable for summer use (although I haven't done anything but snow clearing with this rear blade in a couple years).
   / Back blade for snow removal #33
View attachment 539353 View attachment 539354 View attachment 539355
Thanks for posting the pics. I've been wondering how to attach a pipe, now I have a plan😁
   / Back blade for snow removal #34
I used a back blade for a lot of years moving snow. I like the pipe idea for until a driveway gets froze, once mine got froze I'd scrape it as clean as I could. Parts of my driveway I would drive forward rolling the snow off to the side parts of it I'd spin the blade around and push it, some places sideways some straight back. These pictures are from several years ago.
you can move quite a bit of snow with a back blade.
   / Back blade for snow removal #35
Thanks for the pics! I had a wet snow this week and the mat smeared as much snow as it moved on the concrete. I may have to give this a try sometime.
   / Back blade for snow removal #36
I do worry that pushing the blade backward will bend 3PH components, especially if pushing very hard. I only do that rarely and gently. Don't think I could make 6 foot high snow piles with my rear blade. The blade is only about 3 feet high and doesn't have all that much lift. I think before the snow would rise that high my wheels would start spinning.
It's kind of a pain to flip my blade around. I have to loosen some big nuts, offset the blade enough to spin it, spin it, and then recenter it, and tighten the bolts. If I don't have the blade fairly centered the blade it will tilt enough when raised to drag a corner on the ground.
   / Back blade for snow removal #37
My blade is only about 16" high and only gets about 30" off the ground. When i hit a pile the blade floats up and the back wheels of the tractor go right up the pile and pack some. The next time they go higher.
Your blade not turning is a pain. Mine I just pull a pin and hand rotate the blade to angle it or turn it all the way around. takes way more time to get off and on the tractor.
   / Back blade for snow removal #38
........................................ Mine I just pull a pin and hand rotate the blade to angle it or turn it all the way around. takes way more time to get off and on the tractor.
That is just the way my blade works. Wouldn't have one that didn't work adjust like that.
I thought about how handy a hydraulic cylinder to vary the angle of the blade would be but then I wouldn't be able to rotate the blade 180 degrees, even by hand. I push with the blade rotated backwards to clear the snow if the ground is not yet frozen. It eliminates the need for a pipe add-on to prevent the blade from digging in our gravel driveway.
Not that s219's modification isn't a good one, just that we all have our own methods of which works best for ourselves.
   / Back blade for snow removal #39
Last month we had 6 inches of snow that required me to put on the rear blade. I am 58 years old and I can count on one hand the number of times I have plowed snow with the rear blade. I used my father's old Super Rhino 8 footer that has multiple adjustment angles. Once set correctly it does a great job. My only suggestion is to float the rear so that you don't dig in the roadbed. That comes with experience. I have a gravel driveway. The results were fine. If I lived where snow removal was a weekly chore the rear blade would be my weapon of choice along with a nice heated cab.
   / Back blade for snow removal #40
Some blades (e.g. Rhino), they just put a second hyd. cylinder connection 180 degrees apart from the other. Just pull the cylinder pin, rotate blade 180 and reconnect. Maybe there's a way, a will, and a welder that can do same?
So what's the consensus:
Should you "reverse" the blade so that it is oriented to plow-push backwards? I've always heard not to do this since there is no trip function and 3 point hitches are made to pull, not push, i.e. you risk damage?
I can definitely see an advantage of being able to drive away forward from the pile in the path you just plowed in reverse, and not be trapped.
A tip I learned was for plowing on ground that's not totally flat is to pull the "tilt" pin, or set the equivalent hydraulics to "float", so that the blade tilts/ floats and follows the contours of the ground. -Of course I discovered this after spending $800 (in parts) to add the second hydraulic function before buying the blade. Oh well, still handy when ditching dirt. Hmm, maybe the cylinder is correct length to relocate to the "offset" function, which would be handy when trying to "reach out" next to buildings and fences.
2015 Nissan Frontier Ext. Cab Pickup Truck (A56858)
2015 Nissan...
Mini Excavator Quick Coupler (A55272)
Mini Excavator...
*Selling at Royal Auction Zephyrhills, FL Location* Year: 2005 Make: Mitsubishi Fuso Model: FE84D (A59230)
*Selling at Royal...
New/Unused Quick Attach Pallet Forks (A57454)
New/Unused Quick...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
Year: 2016 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55853)
Year: 2016 Make...
