Back blade build started
   / Back blade build started #1
camshawn
Langley BC
Mihindra 3616
Hello all:
I have been working on a new back blade for our new tractor for the last few weeks as time permits.
I now have most of the steel cut and drilled as needed. I have 2 pieces to take to work to get broke and several small pieces to still acquire.
I still have to source the blade itself and a cutting edge.
Cam
some more pictures.
Cam
   / Back blade build started #3
Looks like it will hold to a tractor twice as big as the photo. Should be fun to see how you would do it since I'm working on upgrading one myself. Wish you good luck
   / Back blade build started #4
What is the four post lift under the tractor ? Factory or garage fabricated ? Looks like a compact design made for tractors and equipment.
Reference the rear blade. Looks like a lot of planning and hours of building. I bought a used model ( because they are cheap and available ) and sold one I got for free. A MIG welder and a Ellis bandsaw can occupy me for days. Just " fun " work.
Blade work continues, gathering parts from the plasma table at work, measuring and tacking. No pictures today. I was hurt last year so I have spent lots of time planning and this project was a good reason to upgrade my welder and purchase a plasma cutter ( and Christmas is coming). The hoist in the background is an old 4 post drive on one, 2 18" platforms that you drive the truck onto. I built 3 plywood boxes to fill in the hole when the platforms are down.
Cam
Work continues as time permits (having a job does get in the way).
I have tacked up things as you can see in order to measure and cut the next pieces. I have drilled and tapped holes for the pivot shaft covers and positioned the top pivot bracket for measuring the mounting pieces.
I got back at the back blade this morning for a few hours. The mounting for the top pivot pin is now complete. The 3 pt mounting brackets are done as well. Just need to add a couple of gussets to keep the top link and upper pivot bracket where I have put them. I have a bunch of pieces laid out to cut tomorrow. The new wire feed welder (Thermalarc fabricator 211i) is working great and I am getting better with each weld.
Cam
update, Back blade build started
Here are a couple of more pictures, Work is slowly progressing.
The blade is to be rolled tomorrow.
   / Back blade build started #9
Looks good! With a little more practice, you won't need to do much grinding at all. I think the least of amount grinding looks the best and also allows for the best paint job.
Backblade is on a delay code today. I went to pick up my blade that was being rolled at a local shop. There were 2 pieces in a pile, one 12 inches wide rolled into a 3/4 pipe section and beside it was it's big brother, a 24" snowplow blade rolled the same way. Someone did not get the concept of a snowplow.
Cam
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A51222)
2018 FREIGHTLINER...
SET OF 48" QUICK ATTACH MAST PALLET FORKS (A51242)
SET OF 48" QUICK...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
Toro Workman Low Profile Spray system 200 (A50322)
Toro Workman Low...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2018 Nissan Versa Sedan (A50324)
2018 Nissan Versa...
