B8200
/ B8200 #1
Anonymous Poster
Epic Contributor
I have a probelm with my b8200
When i start it... it makes a seeeeee sound and i keep the key turning its starts...i think i should leave like that what do u think????
thanks chuckie
/ B8200 #2
Does it make the sound while the engine turns over, or just when you turn the key to "on"? If it's while the engine is turning over, you may have a bad bearing in the starter.
How long do you use the glow plugs?
Does it make the sound when starting cold, hot, or both?
/ B8200
When it turns over...
20seconds when its cold...
both
because its old [2000]
ill buy a new b8200
/ B8200
both
ill buy a new b8200
/ B8200
Why dont you take it in too the dealer they will fix it...
2000 are not old....
/ B8200 #6
Does the squeeeeeel go away once it starts? If so, it's something simple inside your starter. That should be cheap to have fixed. Around these parts, there's a couple of electric motor places that'll rebuild a car starter for about $75.00.
The B8200 was made mid 80's, so it's not very old. Mine only has 750 hours so far... Now my '41 Farmall, that's starting to get a little old...
/ B8200 #8
I've dreamed of having some extra bucks some day. If I were to get another tractor, it'd be a Deere 4300, or Kubota B2910. Both are basically the same size as the B8200, but have oodles more power.
The BX2200 looks real nice, but if I switched, I'd like the extra ponies.
SHOPBUILT TRI-AXLE COMBINE HI-CYCLE TRAILER (A63291)
SHOPBUILT TRI-AXLE...
Root Rake Loader Attachment (A59228)
Root Rake Loader...
2016 Chevrolet 2500 HD 4WD (A63689)
2016 Chevrolet...
Crustbuster 6020 TW36X6 (A64119)
Crustbuster 6020...
Pull-Behind Spreader Tractor Attachment (A61572)
Pull-Behind...
2018 INTERNATIONAL LT625 DAY CAB W/ WETLINE (A62613)
2018 INTERNATIONAL...
