B7800 won't start
/ B7800 won't start #1
avorancher
Deluz, CA
Kubota B7800, RTV900
B7800 won\'t start
I started my B7800 and let it idle for a couple minutes this morning, then shut if off for about 15 minutes. Now, when I try to start it, it fires and turns over, belches black smoke and immediately dies. If I hold the starter on, it can't quite run on it's own but I can hear it firing. (has fuel in tank :))
I waited a couple hours in case it was flooded, but it still acts the same.
Ideas?
/ B7800 won't start #2
Re: B7800 won\'t start
I'm no expert by any means but how does the fuel filter look. My massey ferg. did that when the filter plugged up
/ B7800 won't start #3
What is the history of the Diesel in the tractor's tank? Just started after a long winter's rest. Just filled from a jug I had since last year. Recently refilled and ran with no problems. Just refilled from a fresh tank. Ran last week on the last year's tank just fine.
Water, fungus, dirt are all culprits and filters gets some of 'em but not all. A little history will help with diagnosing fuel problems (if any).
/ B7800 won't start #4
Make sure the fuel tank is full of diesel fuel instead of gas /forums/images/graemlins/shocked.gifline. Don't laugh, $#it happens.
/ B7800 won't start
I'm sure it is diesel... and it has been running perfect until this incident. I haven't fueled up for a week or so.
Tomorrow I'll check out the filter to make sure it isn't plugged... not getting fuel would make it act like this.
/ B7800 won't start
Found the problem.... the air cleaner was packed tight with a mouse nest and it must have been blocking nearly all the air. As soon as I removed it, the orange beast started up right away. This also explains why I've been seeing a little back exhaust smoke when pulling loads lately.
Mice are particularly bad this year due to a wet winter. They have chewed the automatic choke wire on my pickup, and one died in the heater fan of my car. /forums/images/graemlins/frown.gif
/ B7800 won't start #7
Just something to remember on any engine, black smoke means it's getting plenty of fuel and not enough air therefore not having a complete combustion in the cylinder.
That was one smart mouse to be able to get in the air filter housing /forums/images/graemlins/ooo.gif
/ B7800 won't start #8
</font><font color="blue" class="small">( and one died in the heater fan of my car.
)</font>
OH BOY! I BET THAT SMELLED GREAT /forums/images/graemlins/shocked.gif Glad you found the problem
/ B7800 won't start #9
those pesky little bastards...
Cattle Feeder (A65640)
ALLMAND MAXI LITE 8KW LIGHT TOWER (A65643)
ALLMAND MAXI LITE...
New/Unused AGROTK Tire Changer (A65583)
New/Unused AGROTK...
(3) 17.5-25 industrial tires on Deere 14-lug grader rims, Coal Valley, IL (A65640)
(3) 17.5-25...
9ft. Kewanee 3 Point Blade (A65640)
9ft. Kewanee 3...
Lonestar Panel 24ft. Free Standing Panel with Feed Bunk (A65640)
Lonestar Panel...
