B7800 won't run and has no power
   / B7800 won't run and has no power
I finally got it running. I emptied the tank, again, blew out the lines, again, bled the injectors and changed the fuel.
Started up and ran like a champ.
I had done all of the things I've been posting (new filters, checked for debris, etc.) and trying posters' suggestions to no avail. I bled the injectors and the tractor ran better but not correctly at all. I dumped out the fuel I was using which was fairly fresh and got new.
I started her up and she's been running fine since.
Thanks for all the suggestions and input.....they really helped!
   / B7800 won't run and has no power #14
If you can squeeze the suction line with
moderate finger pressure the old fuel line
is too weak and will collapse.
If you have original fuel lines they wil have
been damaged by ozone as well so its good
thing to do in general.
Just be sure to replace the old fuel lines with the
Racor reinforced fuel line.
I am not trying to spend your money, I just want you
to have zero problems as a fuel line problem can be
dangerous.
Tafe 45DI (A60462)
Tafe 45DI (A60462)
UNUSED IRGC80 Battery Powered Golf cart (A55272)
UNUSED IRGC80...
Toro Greensmaster 3150-Q Riding Mower (A56859)
Toro Greensmaster...
2020 CATERPILLAR D5 LGP HIGH TRACK CRAWLER DOZER (A60429)
2020 CATERPILLAR...
WBrock Meyer 2000S 70'x12' 2000 BPH Grain Dryer W/Legs&Mill Discharge Sylo,Controller is included (A57148)
WBrock Meyer 2000S...
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
