B7800 won’t start
/ B7800 won’t start #1
Gto19
Salinas ,ca
Kubota b7800
Hey guys
I have a 150 hour b7800 tractor that is a garage queen . I mainly use it to mow my field. I turned it off and now it won’t crank . Lights all come on though . I checked all the safety switches except the clutch safety switch because I don’t know how to get to it . I see the white connector though . I can easily start the tractor with a long jumper wire I made to go to the positive side of the battery to the starter .It will turn off with the key . Any help before I call a mechanic?
I’ve also tried rocking the forward reverse pedal to its sweet spot with no luck
/ B7800 won’t start #2
Track down that clutch safety switch before you call a mechanic. Follow the linkages.
/ B7800 won’t start
Yes I can see the clutch safety switch. It’s a plunger style like the other three
/ B7800 won’t start #4
Are the PTO levers in off position? That’s the first thing I check when I have no engine turnover when key is turned to start position.
/ B7800 won’t start #5
Ok. You said you didn’t check it. Sounds like you have now??
Mine had to be adjusted because it had backed out a little. Pretty easy fix if that’s the problem.
/ B7800 won’t start
Yes
Always the first thing i check
/ B7800 won’t start
I haven’t checked the switch with my volt meter because the plug is buried but I can see the plunger part of the switch and it’s making contact with the clutch bar when I engage it
Thanks guys
2004 CATERPILLAR 416D BACKHOE (A60429)
2004 CATERPILLAR...
2018 CATERPILLAR 232D SKID STEER (A64279)
2018 CATERPILLAR...
2016 GMC SLT 3500 Pick Up (A62613)
2016 GMC SLT 3500...
2013 Freightliner CASCADIA DAY CAB (A59575)
2013 Freightliner...
2015 Texas Trailers FB3330B 22 Ton T/A Tag Trailer (A61573)
2015 Texas...
2016 WEILER P385A ASPHALT PAVER (A63276)
2016 WEILER P385A...
