B7800 won’t start
/ B7800 won’t start #1
Gto19
Salinas ,ca
Kubota b7800
Hey guys
I have a 150 hour b7800 tractor that is a garage queen . I mainly use it to mow my field. I turned it off and now it won’t crank . Lights all come on though . I checked all the safety switches except the clutch safety switch because I don’t know how to get to it . I see the white connector though . I can easily start the tractor with a long jumper wire I made to go to the positive side of the battery to the starter .It will turn off with the key . Any help before I call a mechanic?
I’ve also tried rocking the forward reverse pedal to its sweet spot with no luck
/ B7800 won’t start #2
Track down that clutch safety switch before you call a mechanic. Follow the linkages.
/ B7800 won’t start #5
Ok. You said you didn’t check it. Sounds like you have now??
Mine had to be adjusted because it had backed out a little. Pretty easy fix if that’s the problem.
/ B7800 won’t start
I haven’t checked the switch with my volt meter because the plug is buried but I can see the plunger part of the switch and it’s making contact with the clutch bar when I engage it
Thanks guys
/ B7800 won’t start #8
Wow!
An 150 hour B7800 is a garage queen indeed!
Good Luck with your diagnosis!
Could it have the OPC(Operator Presence Controller)system?
Just a thought,
JCB 510-56 TELESCOPIC FORKLIFT (A64279)
JCB 510-56...
2018 HINO 338 KNUCKLE BOOM TRUCK (A63276)
2018 HINO 338...
2006 Ford F-250 Crew Cab Pickup Truck (A61573)
2006 Ford F-250...
2022 EZ-GO ELITE...
Komatsu PC138USLC Excavator (A64047)
Komatsu PC138USLC...
72"Skid Steer 4 in1Bucket (A62613)
72"Skid Steer 4...
