B7800 will not run after rain?
   / B7800 will not run after rain?
Is this right? Seems kinda silly or missing some info. I don't have the book just found this online.
   / B7800 will not run after rain? #12
That is what my book says, not very clear on what is going on BUT fill tank with fuel is a big part of the procedure
I can't even get it started. Battery is weak from trying but even with a jump starter it still just turns over.
Not sure what to do since it started and ran for a a min then died.
If it was anything else i would check for a spark.
   / B7800 will not run after rain? #14
When you installed the new fuel filter, did you let the small canister fill with diesel before tightening the bowl? That eliminates any air in the system, and if you did not do that, yes, the engine will run until it pulls that air in, then you need to crank it to remove it.
You could still crack open the fuel filter and make sure there is no air now and there is good fuel flow, but you either need to crank it over to get the air out of the system. I would try the crank method before loosening the injector lines - that's a last resort.
Actually when i removed the small canister diesel fuel never stooped flowing the bowel was full by the time i got it back on.
   / B7800 will not run after rain? #16
So you replaced the filter without shutting off the fuel, I guess? That eliminates air and its not leaking any now after replacing the filter?
   / B7800 will not run after rain? #17
Here is a pretty good video about the fuel cutoff solenoid. He shows how to prime the engine at 20:50
Okay i got it started didn't do anything to it, the 30 amp fuse was fine and i can hear the solenoid turn on. Looks like it had been replaced at some point as it was the cleanest part in there.
I bought this tractor off my neighbor last year for real cheap almost free with 600hrs on it and i told him what it was doing and he had the same issue after it rained and never could figure it out. Had it at the local dealer and they said nothing was wrong with it.
I did noticed that black smoke came out when it did start as normal and before nothing was coming out of the exhaust when it would just turn over and not start.
It's been outside it's whole life.
Does anyone have a idea of why it does this? It has to be a good amount of rain, it rained 3 inches the other day.
   / B7800 will not run after rain? #20
OK so it started now with a puff of black smoke, which is normal in the first few seconds after starting.
I suspect it was the plugged air filter, when its wet / damp the pores of the filter are so plugged it can't get air - though its rare, it is possible if you are in a damp, humid environment and have dust too - this will then grow algae inside further blocking the air.
Mendosy said "Another possibility is that the air filter got wet and isn't allowing enough air into the engine" I think it the best diagnosis I can see from my limited view!
2005 GMC Canyon (A57148)
2005 GMC Canyon...
2016 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2016 UTILITY VS2RA...
2015 Peterbilt 389 T/A Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 389...
Tandem Axle Rear Truck Frame (A59230)
Tandem Axle Rear...
WIGGINS 5K FORKLIFT (A58214)
WIGGINS 5K...
2018 CASE 340RT TRACKED TRACTOR (A60430)
2018 CASE 340RT...
