B7800 Pedal Problems?
/ B7800 Pedal Problems? #1
Temp97
Western New York
When I start my tractor and hit the pedal to move (forward or reverse) the tractor shuts off????? I'm thinking something is shorting out but not sure where. 1st thing I checked were the connections under the seat and they seem OK. Any one else have this problem or suggestions. (I hate tracing electrical problems).
Thanks
/ B7800 Pedal Problems? #2
Almost certainly a safety switch issue - simply a matter of finding it. I agree that the seat would be my first suspect... Good luck!
Mike
/ B7800 Pedal Problems? #3
Engage the PTO while your sitting and then stand up. What happens?
/ B7800 Pedal Problems? #4
Operator switch under the seat is the problem more then likely!
/ B7800 Pedal Problems? #5
I got around to trying that last night, here's what happens. Sitting down and engaging the PTO it shuts off instantly. Get off the seat and engage the PTO it shuts off after about 3-4 seconds. I checked all the wires and cleaned them (under the seat) but no luck. The tractor is a 2007. There is a small box (circuit breaker looking thing) under the seat that I'm starting to believe may be shot. This weekend If I have time I'm going to crawl underneath it and trace wires/connections before I have to take it to the shop,,,
/ B7800 Pedal Problems? #9
Ok, sounds interesting. There is plug right by the seat, have you unplugged that, cleaned it, and gotten it back together? Mine was acting up like this one day. I think I also adjusted the seat itself a few times. Trying to distribute the weight while trying to figure it out myself.
I am thinking if it is electrical, you would not be starting at all, or the behaviour on the shut-off would be identical.
/ B7800 Pedal Problems? #10
if you tilt the seat up while you engage the pto if your seat switch is bad it should still keep running because there is a second switch on the seat that activates when the seat is tilted up so that you can run the pto without being on the seat.
this test will tell you if your seat switch is bad. if the pto runs with the seat up but dies with the seat down it means that the tractor thinks no one is in the seat
hope that helps
/ B7800 Pedal Problems? #11
Classic seat bottom safety switch.
Pull the two wires off of the switch terminals, jumper them together - *but wrap them (e.g., with electrical tape) so they don't short to any other part of the tractor and blow a fuse* - and see if that doesn't solve your problem.
If it does, you need a new switch. Or, you can jumper the wires together permanently if you don't care for this "feature".
Dieznutz, Didn't get a chance to look at it last night but I will run that test tonight, thanks. Also Jonsstihl, it does run with the seat up and I was wondering why there were 2 switches.
/ B7800 Pedal Problems? #13
In case I wasn't clear enough, it's the seat bottom switch wires you want to jumper/test. Not the seat tilt switch (the one at the front edge of the seat) - it isn't your problem, you can leave it be.
The sole purpose of the tilt switch is to allow you to run the (rear only) PTO stationary while not sitting on the tractor. Normally if you had the PTO on and got up, the tractor would quit. Tilting the seat is an "override" that tells the tractor "I'm definitely not sitting on the tractor but I definitely want to run the PTO."
Everything you described is what happens when the tractor thinks you're not sitting on the seat *and* the seat isn't tilted - i.e., bad seat switch isn't closing the circuit.
/ B7800 Pedal Problems? #14
Here's the Operator Presence Control manual pages for the 7800
  • Operator Presence.pdf
Ooops, to late. I ran the test last night and read your new message this morning. I did what you said and taped the 2 wires together for the seat tilt switch (left one in pic) and it worked,, seat up, seat down w/PTO on... Now that I'm thinking of it I didn't actually sit on the seat to make sure there was pressure on the seat switch (round one),,,,
test drove it last night and it works fine with the wires taped together. Have to order one of those switches. Thanks for the help....
/ B7800 Pedal Problems? #17
Happy to help, glad it was that simple. :)
JOST FIFTH WHEEL PLATE (A64276)
JOST FIFTH WHEEL...
2011 BRENNER TANK PUP TRAILER (A67714)
2011 BRENNER TANK...
2021 PETERBILT 367 (A65643)
2021 PETERBILT 367...
CAT D9G Rollers (6) (A68134)
CAT D9G Rollers...
CRATE OF FLANGES AN PIPING (A67714)
CRATE OF FLANGES...
2015 Audi A4 AWD Sedan (A61574)
2015 Audi A4 AWD...
