B7800 over heating?
/ B7800 over heating? #11
Don't forget that the radiator can be plugged up inside which will give you a hot top hose and cold bottom hose.
Yep. On a high hours older tractor that is a consideration. In this case, with only 300hrs on it, much less likely.
/ B7800 over heating? #12
Unless incompatible antifreeze were mixed and or poor quality water.
/ B7800 over heating? #13
I'd wash out the radiator first. If you don't resolve the issue I'd be checking the temperature with another set of gauges. I don't think my tractor's would overheat with a mostly plugged radiator idling. Especially inside of 15 minutes.
/ B7800 over heating? #14
Yep. To overheat in 15 minutes means a "closed" system. No circulation.
2018 Chevrolet Traverse SUV (A60352)
2018 Chevrolet...
2023 Kubota M4-061 Deluxe MFWD Utility Tractor with LA1154 Front Loader (A55315)
2023 Kubota M4-061...
Metal Hoist Bracket (A59317)
Metal Hoist...
CFG Industrial 680 QA Hydraulic Hummer (A60463)
CFG Industrial 680...
Kubota MX5400 land mgmt package
Kubota MX5400 land...
2008 CATERPILLAR 420E BACKHOE (A59823)
2008 CATERPILLAR...
