B7800 Mid PTO/Rear PTO operation
   / B7800 Mid PTO/Rear PTO operation #1
dmnsmith2
Alabama
03 Kubota B7800
One of the mechanics told me at the local Kubota shop that on a B7800 when lowering or raising the belly mower (mid PTO) the rear implement would rise also, vise versa for lowering. I am kinda confused by this.
So if you want to leave your mmm on and want to use a box, tiller, etc on the rear, I would think the mmm would be in the way having to be lowered. Seems you'd have to take the mmm off according to what he was saying.
Or can you lock the mmm all the way up, then be free to go up or down on the rear? Hope I explained the confusion. Thanks!!
   / B7800 Mid PTO/Rear PTO operation #2
The same holds true on the BX series tractors. The same lift mechanism services the 3pt and the MMM...HOWEVER, on the BX, you can adjust the MMM to stay up high by turning the height adjustment knob to "Top" while it's raised. You may have that feature on the B-series, but I don't know for sure.
That being said, leaving the MMM during earth-moving chores may not be the best idea. It's very easy to get rocks, etc., in places that they shouldn't be...if you do leave it on, be sure to carefully check and clean the MMM before you use it. Personally, I take mine off when moving more than a little mulch or other very minor tasks involving ground engagement. It only takes a few minutes to do so...
   / B7800 Mid PTO/Rear PTO operation #3
My B7500 has pins that you install to keep the MMM up when you use the 3PT. You should find a reference to it in your operator's manual. As I remember it was in my manual for the B7500. The B7800 should be the same.
   / B7800 Mid PTO/Rear PTO operation #4
Like Gus said, you can pin the MMM up. But if you have any amount of loader work to do, just remove the mower deck. I can take off the 72" deck in about 2 min. with the loader on and less than 5min. with the loader off. Without the deck on its one less thing to worry about.
2022 Weber MT CF2A Plate Compactor (A51691)
2022 Weber MT CF2A...
2011 INTERNATIONAL PROSTAR TANDEM AXLE SLEEPER TRUCK (A52577)
2011 INTERNATIONAL...
PREVIEW DATES AND TIMES (A51572)
PREVIEW DATES AND...
1998 Ford F800 2,000 Gallon Water Truck (A52377)
1998 Ford F800...
Deutz 2WD 53HP Utility Tractor (A51691)
Deutz 2WD 53HP...
2025 New/Unused Wolverine Pallet Fork Extensions (A51573)
2025 New/Unused...
