B7800 making noise in high gear only!
   / B7800 making noise in high gear only! #1
Cajun_MD
I have a B7800 HST 4x4 with about 120 hours. We use it manly for mowing 4 acres. Yesterday it started making a noise when moving in high gear. It's hard to describe the noise. It's not grinding or crunching. It kind of sounds like the cartoon Jetson's car. Switched to medium and low and nothing. The noise is louder when going full speed and goes down when the speed goes down (or as I let up on the pedal). It seems like a pump issue, but I don't know. The performance is not affected. It still pulls and mows flawlessly just a funny noise when in high gear travelling to different areas. Thanks in advance for your help.
Craig
   / B7800 making noise in high gear only! #2
Did you accidentally engage one of the PTOs that you don't normally use?
   / B7800 making noise in high gear only! #4
That sounds exactly like what I am experiencing. I really couldn't describe the noise, but you guys nailed it. Thank you very much for the info. That is a very quick fix. I knew it couldn't be much.
PALLET OF (2) TRIPAC THERMOKING UNITS (A50854)
PALLET OF (2)...
Toro Zero Turn Mower (A50324)
Toro Zero Turn...
2017 Peterbilt 567 Tri-Axle Dump Truck (A49461)
2017 Peterbilt 567...
2025 Safety Basket Forklift Attachment (A50322)
2025 Safety Basket...
2017 POLARIS RANGER 570 4X4 PROSTAR UTV (A51406)
2017 POLARIS...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A49461)
2019 Allmand...
