B7800 making noise in high gear only!
   / B7800 making noise in high gear only! #1
Cajun_MD
I have a B7800 HST 4x4 with about 120 hours. We use it manly for mowing 4 acres. Yesterday it started making a noise when moving in high gear. It's hard to describe the noise. It's not grinding or crunching. It kind of sounds like the cartoon Jetson's car. Switched to medium and low and nothing. The noise is louder when going full speed and goes down when the speed goes down (or as I let up on the pedal). It seems like a pump issue, but I don't know. The performance is not affected. It still pulls and mows flawlessly just a funny noise when in high gear travelling to different areas. Thanks in advance for your help.
Craig
   / B7800 making noise in high gear only! #2
Did you accidentally engage one of the PTOs that you don't normally use?
   / B7800 making noise in high gear only! #4
That sounds exactly like what I am experiencing. I really couldn't describe the noise, but you guys nailed it. Thank you very much for the info. That is a very quick fix. I knew it couldn't be much.
2011 KENWORTH T800 SLEEPER (A50854)
2011 KENWORTH T800...
2022 Continental 16ft T/A Enclosed Trailer (A49461)
2022 Continental...
2002 Ford F-650 Crew Cab Dump Truck (A48081)
2002 Ford F-650...
2013 INTERNATIONAL PAYSTAR DAY CAB ROAD TRACTOR (A51406)
2013 INTERNATIONAL...
2015 Dodge 5500 4X4 Bucket Truck (A51039)
2015 Dodge 5500...
2009 L3 GENERATOR SET (A51222)
2009 L3 GENERATOR...
