Oil & Fuel B7800 Hydraulic oil change
   / B7800 Hydraulic oil change #1
MarkyP
I purchased a Kubota B7800 from Bob Wolf @ Woodbury tractor 7 years ago at 40 hours 6 years ago I had Bob do the service. Now don't mad but I now have 70 hours on the tractor. When I had the service done I purchased all the fluids and filters I would need to do it my self.
I would like to state I am by no means a shade tree mechanic but the fluids I feel I can take care of with out a hitch LOL. I did the oil the other day using Rotella no big deal.
Now for some reason I can not find my owners manuel. I have everyone for all the attachments but here's where I am lost. If you are sitting on the machine near your right foot when using reverse is a yellow dip stick, this is a little low. I wanted to know If I wanted to add some fluid I so this under the seat is a Yellow capped plug. I have 2 5gal buckets of Kubota Superior UDT
hydraulic trans fluid? Is this where this fuid is added.
Should I change this fluid now or wait til I have 80 hours on the machine?
Thanks
Mark
   / B7800 Hydraulic oil change #2
If you changed the tranny fluid @ 40 hrs. there is no need to change it now. If you did not you should change it. I have attached some manual pages for you. The yellow plug under the seat is where you put in the tranny fluid.
  • IMG.pdf
  • IMG_0001.pdf
   / B7800 Hydraulic oil change #3
FWIW - Six years is long time. Most manufacturers have both calendar and hour time recommendations. If you live in very dry conditions or park in a temperature controlled garage perhaps you can get by.
Personally if I had the stuff sitting there I would go for the change
Where did you get that book. If you could post a link I would order one up today. Thanks again and I am going to change the fluids. Wish me luck.
New/Unused 13ft x 20ft Single Garage Metal Shed (A51573)
New/Unused 13ft x...
Miller and Smith PNR-1000 Pull-Behind Proof Roller Trailer (A52377)
Miller and Smith...
2015 CATERPILLAR 262D SKID STEER (A51246)
2015 CATERPILLAR...
(3) 55-Gallon Drums of Fertilizer (A51573)
(3) 55-Gallon...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
